WIN10 Issues: TP-Link WN722N Network Card Not Detected After Driver Installation
dariog8 9498 8
  • #1 16772847
    dariog8
    Hello. I have a problem. I installed windows 10 from scratch. I connected the tp link WN722N card. I have downloaded the drivers. And yet the computer can't see my card. There are no exclamation marks in the Device Manager. What have I done wrong?
  • #2 16773004
    bogiebog
    Help: 2569
    Rate: 1530
    The system cannot see the card
    - card broken?
    - USB port broken
    and this "WIFI" network connection on the screenshot is what?
  • #3 16773011
    dariog8
    card is working because it works on other equipment. USB ports are also functional because I connected other devices
  • #4 16773027
    bogiebog
    Help: 2569
    Rate: 1530
    Run linux live from USB and check if linux can see this card.
    from the console / shell
    lsusb
  • #5 16773041
    dariog8
    My motherboard if I remember correctly no boot option from usb
  • #6 16773119
    jprzedworski
    Help: 758
    Rate: 828
    Which hardware version? The manufacturer's website has a driver for Windows 10 but only for the hardware version V2.
  • #7 16773193
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    If the signature from the network connection is correct (AR9271) it is V1, V2 was on Realtek. Drivers for V1 from the TPLink page contain a directory for Windows 8.1, I used them under Windows 10 and functioned correctly.
  • #8 16773877
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Show device manager.
  • #9 16775139
    dariog8
    It helped. Thanks for the help
The discussion revolves around a user experiencing issues with the TP-Link WN722N network card not being detected after a fresh installation of Windows 10. Despite installing the appropriate drivers, the card remains undetected, with no errors shown in Device Manager. Responses suggest checking the hardware version of the card, as drivers for different versions (V1 and V2) may vary. It is recommended to verify the card's functionality using a Linux live USB and to ensure the correct drivers are used based on the hardware version. The user later confirms that assistance received helped resolve the issue.
