How Bluetooth Adapter Works: Connect TV to Phone, Receive Audio on Headphones
bobek5432 3897 4
  • #1 16773150
    bobek5432
    Hello, will I be able to receive audio on the headphones on the phone by connecting the bluetooth adapter to the TV and then connecting to it via the phone?
  • #2 16773161
    lukasixthm
    Help: 60
    Rate: 381
    99% not. I have not seen USB audio streaming on TV.
  • #3 16773324
    bobek5432
    There are bluetooth adapters with jack special, I thought about them more.
  • #4 16773368
    lukasixthm
    Help: 60
    Rate: 381
    But through this jack the audio signal comes out of the adapter, not the other way around. You can then add bluetooth aux to the amplifier, for example. You connect such an adapter with a chinch-jack cable to the amplifier, and you send music from the phone to the adapter. You want the other way, and you can't.
  • #5 16773378
    bobek5432
    Thanks for the answer.
