Transferring sound from the computer to the bluetooth receiver
kriss0506 9603 1
  • #1 17056698
    kriss0506
    Rate: 8
    Hello. I have a problem with streaming audio from an HP2000 (win 8.1) laptop with a built-in bluetooth module to an external bluetooth module that is connected to the amplifier. An android phone sends without a problem, while in the case of a laptop I have a problem because it seems to be evaporating and is detectable, but what's next ... The music is still playing in the computer's speakers and there is no option to send the sound via bluetooth.
  • #2 17056887
    mladenick
    Help: 14
    Rate: 90
    In the sound settings you probably have a choice, it can be in the advanced settings, if you have some audio program, it can be there, bluetooth often appears as a type of headphones, I e.g. switch between speakers in the computer, USB headphones if they were plugged in and the bluetooth speaker (Sharp) appears as Sharp headphones, most often, after switching the device you need to restart the player,
