Integra Satel: DLOADX Key Change Issue - Unable to Connect with New or Old Keys, Solutions?
mirofm 18753 4
  • #1 16773663
    mirofm
    Using the Dloadx program, I changed the Dloadx key in the settings and saved me from the program by saving to the control panel.
    I entered the communication configuration, changed the settings to the key that I changed, but the program does not want to connect to the program. Now neither the old Dloadx key nor the new one works. How can you deal with it ??
  • #2 16773994
    alster1
    CCTV and Stationary Alarms specialist
    Help: 352
    Rate: 540
    From the keyboard level, in service mode you can read and change the DloadX key
  • #3 16774069
    mirofm
    Can you write something more about it?
    alster1
    Help: 352
    Rate: 540
    What more to write here? On the keyboard, the service mode, structure, hardware, manipulators, ethm and you are looking for the DloadX key.
  • #5 16774227
    mirofm
    Buddy, it worked. You saved another innocent life!
    Thanks.
