Satel ETHM-1 Plus: Programming Integrated 64 Apartment System via LAN in DloadX - IP & Port Issues
nelik1987 6621 6
  • #1 16802054
    nelik1987
    Help: 43
    Rate: 428
    I am programming integrated 64 in the apartment. I have the ETHM-1 Plus module connected to it. I programmed everything in the control panel via the USB cable and now I would like to program via LAN. Unfortunately, the following message is still displayed in DLOADX. I have set the correct IP and port. The ETHM module works fine because it works on my KPD mobile phone.
    I will add that I have not changed the ID of the control panel and it is the default.
  • #2 16802090
    suworow
    Help: 650
    Rate: 1278
    Are they compatible?
  • #3 16802168
    nelik1987
    Help: 43
    Rate: 428
    Well, I expect them to be incompatible, but I don't know where to compare them, I looked in the LAN module settings but found nothing. Where to look for it?
  • #4 16802190
    suworow
    Help: 650
    Rate: 1278
    Where are the other IDs? It may also be that they wrote something about it in the manual. ;)
  • #5 16802212
    nelik1987
    Help: 43
    Rate: 428
    OK, I managed to find the control panel identifier and DLOADX identifier in the keypad (in the service mode settings), copied to the program settings and it works. :)
    Thanks.
  • #6 16802223
    suworow
    Help: 650
    Rate: 1278
    nelik1987 wrote:
    OK, I was able to find the control panel ID and DLOADX ID in the keypad (in the service mode settings)
    So they were in the manipulator all the time? ;)
  • #7 16802230
    nelik1987
    Help: 43
    Rate: 428
    Exactly, but they were well hidden. :)
The discussion revolves around programming the Satel ETHM-1 Plus module for a 64 apartment system via LAN using DLOADX software. The user initially faced issues with IP and port settings despite the ETHM module functioning correctly on a mobile device. After some troubleshooting, the user discovered the control panel and DLOADX identifiers in the keypad's service mode settings, which resolved the connectivity issue. The identifiers were not easily accessible, leading to initial confusion regarding compatibility and settings.
