Xbox 360 Slim Power Plug Diagram: Checking Compatibility with Fat Power Supplies
sewek1000 27408 7
  • #1 16775379
    sewek1000
    Help: 17
    Rate: 26
    Hello, I need a plug diagram from X360 Slim, I bought a used one and I would like to check if it works and I only have power supplies from Fat, and before the adapter comes, it will be a few days in advance, thank you in advance.
  • #2 16775716
    Pedros050
    Help: 2471
    Rate: 3927
    Xbox 360 Slim Power Plug Diagram: Checking Compatibility with Fat Power Supplies Hello. Please. Xbox 360 Slim Power Plug Diagram: Checking Compatibility with Fat Power Supplies
  • #3 16775769
    sewek1000
    Help: 17
    Rate: 26
    Thank you for the diagram, this is the power supply diagram of the drive and I need console power :) but it will be useful in the future
    Added after 4 [hours] 31 [minutes]:
    And the second diagram is the Fat Console Diagram needs a slim console :) to solder directly into the socket with cables ;)
  • #4 16776330
    Pedros050
    Help: 2471
    Rate: 3927
    Xbox 360 Slim Power Plug Diagram: Checking Compatibility with Fat Power Supplies Here it is.
  • #5 16776458
    sewek1000
    Help: 17
    Rate: 26
    here it is only in 360 Slim with trinity plate
    Krzychu K.
    Help: 50
    Rate: 100
    greetings.
  • #7 16777112
    sewek1000
    Help: 17
    Rate: 26
    that's exactly what it was about, thank you, it turned out that the Xbox is damaged, only the drive and hard drive are functional, the console has all USBs desoldered for unknown reasons, no WIFI module and after turning on once the fan turns off and turns off
  • #8 16801749
    sewek1000
    Help: 17
    Rate: 26
    I close the topic, the console came to life, the problem was cold February under GPU or RAM, the 0110 code popped up, warming up with Hot 400 degrees on the heat sink for about 5 minutes, made the console work 100%
The discussion revolves around the compatibility of power supplies between the Xbox 360 Slim and the original Xbox 360 Fat models. The user requested a power plug diagram for the Xbox 360 Slim to verify if their existing Fat power supplies would work. Several users provided diagrams, but the original poster clarified that they needed the console power diagram specifically, not the drive power diagram. Ultimately, the user discovered that their Xbox 360 Slim was damaged, with issues including desoldered USB ports and a non-functional Wi-Fi module. After troubleshooting, they managed to revive the console by addressing a cold solder joint under the GPU or RAM, which resolved the error code 0110.
