iPhone 6 (iOS 10.x): Cameras and Flash Not Working After Talk Speaker Replacement
dadus18 6822 5
  • Cameras and flash remain broken after speaker replacement
    #1 16176923
    dadus18
    Rate: 95
    Hello, yesterday I set about replacing the talk speaker in my iPhone 6, obviously not the first time, all carefully and gently. After submitting, it turns out that the cameras and the flash do not work. I repeatedly undressed and folded with the old speaker ... still the same, the application reset does not help, certainly nothing has been damaged, everything is plugged in ..... anyone will help ??? : - /
  • #2 16176950
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    For starters, upload soft in dfu mode via itunes.
  • #3 16177100
    dadus18
    Rate: 95
    I'm just being installed .......
    Added after 25 [minutes]:
    Unfortunately, nothing is still the same problem .....
  • #4 16177814
    gsmowiec
    Help: 27
    Rate: 128
    In this case, only the service because something was damaged. You would have to put in a working camera and see how not to look for damage on the board. This little bit glued with glue near the connectors can barely hold up, something could also be torn off but without diagnosis you can not say anything more.
    It's a bit weird that both cameras were gone.
  • Rear camera still fails independently; iOS downgrade hits error 3194
    #5 16177919
    dadus18
    Rate: 95
    Exactly weird, after all it is on the separate tape as something it fell to one, even the function of the flashlight does not work. Wrzuce still ios 9.3.5 how to succeed and see. Well, thank you for your help.
    Added after 2 [hours] 54 [minutes]:
    Hello once again, I tried to separately attach the rear camera without the front, still the thread. There is a problem because I can not go back to iOS 9.3.5 due to a bug 3194, I tried to make a note in hosts but no effect. Maybe some hint ??
  • #6 16183254
    hacker_ice
    Help: 36
    Rate: 101
    Try to upload through windows 10 or via mac. If the cameras do not work, maybe both at once fall down this way sometimes. Even if you disconnect the camera it's soft and it will sound without error. If it does not help, try with new cameras, if that does not help it's a problem with the motherboard.
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
