VW Touran 1.9tdi 2005 - Engine Control Computer Code 01314, No Ignition Post-Accident
Touran500 8928 7
  • #1 16778970
    Touran500
    Hello all. I have a problem with my Touran 1.9 2005 after the accident (the right front of the airbags fired) I do not want to start, after turning the ignition, the check engine does not light up, nor does the indicator light from the glow plugs, the fuel pump in the tank does not work. All fuses and relays are checked and they are ok. After connecting, the balance shows the code 01314 - engine control computer. Maintaining the speed. Damage
    Please help.
  • #2 16779045
    krychu0505
    Help: 49
    Rate: 114
    Hello, were the cable harnesses intact after the accident?
    This error may be related to a CAN communication error. Check cables where damaged.
  • #3 16779104
    Touran500
    The bunch is complete, tomorrow I will check the driver, maybe there is something wrong with it
  • #4 16779279
    moto-kord
    Help: 137
    Rate: 505
    Check the fuses in the box under the hood to see if any of them fell out during the impact.
  • #5 16779594
    mercedesik
    Help: 80
    Rate: 522
    Look for broken mass near the side members, preferably with damaged places, the error means no communication with the controller.
  • #7 16779840
    krychu0505
    Help: 49
    Rate: 114
    It's not the impact sensor that activates AIR BAGs sometimes?
  • #8 16784708
    witek271
    Help: 19
    Rate: 174
    There is no impact sensor on the Touran like in the French. This is the impact sensor for airbags
    Check carefully the fuses in the engine compartment most important number 24
    01314 - Motor Control Module: No communication
    Possible causes
    CAN-Databus Wiring to / from engine control module is defective
    Errors stored in the engine control module
    The engine control module has recently flashed or has been remapped
    Possible solutions
    Check CAN-Databus wires / connectors from / to Engine Control Module
    Check Value Measurement Blocks (MVB)
    Typically measuring block values (MVB) 125+ show the current communication status
The discussion revolves around a 2005 VW Touran 1.9 TDI that failed to start after an accident, with the engine control computer code 01314 indicating no communication with the engine control module. Users suggest checking the integrity of cable harnesses, fuses in the engine compartment, and the inertia switch, which may have tripped during the impact. The absence of communication could be due to defective CAN-Databus wiring or issues with the engine control module itself. Specific fuses, particularly number 24, are highlighted as critical to check.
