Issues with Toyota Yaris 1.4 d4d: Engine Shut Down, Starter Turns, Persistent Fan Operation
Goral2015 10389 8
  • #1 16779746
    Goral2015
    Hello, I have a problem with the toyota has gone out and I will not start. I was driving it and it suddenly went out. The starter turns and does not fire and after turning the ignition switch and removing the key, the engine fans are working all the time, what could be? The fuel supply is pump running and the filter is a new alternator and starter too. In Polish, it fires from szczał as if the injectors did not open, and what about this fan may not be connected.
  • #2 16779790
    siewcu
    Help: 133
    Rate: 458
    Under what conditions did it go out? The last time I dealt with such a case, the belt (or chain, I don't remember anymore) broke.
  • #3 16780069
    Goral2015
    But on the cake he fires normally, the engine runs, burns from the tick.
  • Engine temperature sensor fault may keep fans running
    #4 16780631
    g107r
    Help: 811
    Rate: 993
    Goral2015 wrote:
    the motor fans run continuously
    This is what I associate with the lack or short circuit on the engine temperature sensor - not the meter, because there can be two sensors, for clocks, and for the engine controller or fans, which I do not know. A "failure" of the sensor would cause the fans to work and the fuel dose not quite right when starting the engine.
    It fires on the cake and does not go out? It could be a sensor, but some engine light should come on :idea:
    And without associations, reading errors would be needed, some computer diagnostics ...
  • #5 16780896
    Goral2015
    When there is no plaque, it goes out. It doesn't connect to any computer
  • #6 16781345
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    Check all vehicle weights and fuses.
  • #7 16781355
    szymitsu21
    Help: 343
    Rate: 1300
    And does the engine or glow plug indicator light come on?
  • #8 16815615
    Goral2015
    Nothing ignites
  • #9 16815739
    szymitsu21
    Help: 343
    Rate: 1300
    Goral2015 wrote:
    Nothing ignites
    so there may be a power problem.
The discussion revolves around a Toyota Yaris 1.4 D4D that suddenly shut down while driving and fails to restart. The starter turns, but the engine does not fire, and the cooling fans operate continuously after the ignition is turned off. Possible causes suggested include a malfunctioning engine temperature sensor, electrical issues, or a power problem. The owner notes that the vehicle does not connect to diagnostic tools, complicating troubleshooting. Recommendations include checking vehicle weights, fuses, and ensuring proper sensor functionality.
