Toyota Yaris 1 (benz.1.0) - Starter does not turn (ignites at pride)
wisz 41661 14
Why does a Toyota Yaris 1.0 petrol crank with no starter click and no dimming lights, and what fuse/relay/switches should be checked first?
Check the starter fuse and starter relay in the engine compartment first, then verify the clutch-pedal switch and whether control voltage reaches the starter solenoid [#17522361][#17522508] In the thread, the fuse was reported OK, the dash display went out when starting, and that was taken as evidence that the ignition switch and clutch relay were probably working [#17523783][#17523806] A practical test is to bridge the relay’s two thick contacts or apply +12 V to the starter side; if the starter spins, the fault is in the control circuit/relay/ignition switch, and if it still does nothing, suspect the starter itself, especially the brushes/solenoid [#17523822][#20025376] One reply specifically pointed to the ignition switch as a possible cause based on a similar case [#17524016]
  • #1 17522290
    wisz
    Rate: 19
    Hello. I have a problem with Toyota Yaris 1 with 1.0 petrol engine. After stopping the car and turning off the running engine, the attempt to start again failed. Details of the operating symptoms in this condition are as follows: after turning the key in the ignition, the lights come on, the electromagnet in the starter is not clicked, the starter does not turn, the engine does not start. I will add that when you try to start, the lights do not even "dim" for a moment, which would mean that the impulse of current consumption from the battery by the main circuit of the starter is not present. The car was able to ignite "pride", thanks to which it was possible to reach the destination.
    I suspect damage to: the solenoid circuit fuse (if there is such protection) or the relay in this circuit (if present) or the solenoid in the starter or the power supply cable of this solenoid.
    The question is, in this model, the starter solenoid circuit has protection and possibly a relay? Common sense should be like that. Unfortunately, I do not know this car enough, hence I do not know exactly which elements are in the fuse box (as I guess the box is in the engine compartment). I want to check these elements before making a decision about going to the workshop, because it can be restored to the vehicle at a low cost. Thank you in advance for all suggestions.
  • #2 17522361
    moto-kord
    Help: 137
    Rate: 505
    Hello, check the fuse and the relay are in the engine compartment.
  • #3 17522508
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Clutch pedal depressed during start-up?
    Is the clutch pedal sensor OK?
    Anything diagnosed - though a "light bulb", there is a control voltage on the starter solenoid?
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #4 17522536
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    I suspect the ignition block or the relay.
  • #5 17522562
    badyl666
    Help: 25
    Rate: 109
    Hello. Check the fuse first and then the relay.
  • #6 17522653
    wisz
    Rate: 19
    Hello. Thank you for your quick response colleagues. I haven't diagnosed anything yet. The description I made was based on the story of a car user who has so much in common with the automotive industry that he drives this car and has nothing to do with electrical engineering or electronics. I'll do the tests and see what the result will be.
  • #7 17522692
    kkknc
    Help: 1915
    Rate: 6709
    Check briefly if it's spinning. That's where starters fall. Without any symptom. And when you press the clutch listen to the knock of the relay?
  • #8 17523783
    wisz
    Rate: 19
    I just did the first tests. Unfortunately, outside, when it was raining, so I didn't delve too much. In the fuse box - the fuse is OK (like the others). When turning the key in the ignition (when the clutch is depressed), there is no click of the relay or the electromagnet from the starter, although the display of the speedometer goes out (but this is probably how it normally is; the other lights do not go out). The voltage meter does not show a temporary decrease in voltage on the battery. The system of relays and fuses is slightly different from the one given in the diagram above. Many fuse and relay sockets are empty (the car is poorly equipped). For example, in the place indicated as the ST Relay (stater) relay, there is a relay with a different lead arrangement. Rather, it resembles the circuit shown for the two relays below. This relay (and only him) has an orange housing, while the others are gray. I took it out of the socket and had two "knife" slides wider, which I think is the relay coil leads and three more "knife" narrower, which indicates the COM-NO-NC terminals. The ohmmeter shows no value on the coil terminals. Was the whipped coil in the relay? I did not try to start the starter "briefly" because of the rain. Someone from my colleagues suggested a possible fault in the ignition socket. Of course this is also possible. Nevertheless, it seems that we are dealing rather with a break in duty. It remains to look for the starter relay and do the test "briefly". Where can you buy such a relay cheap? If the weather conditions improve, I will go back to testing. For now, I'm waiting for the weather to improve. Thank you for your interest in the topic so far.
  • #9 17523806
    kkknc
    Help: 1915
    Rate: 6709
    As the display goes out, the ignition switch works and the clutch relay also. As I remember, I am not mistaken.
  • #10 17523808
    mod22
    Help: 130
    Rate: 312
    Check the incandescent bulb for power to the starter solenoid during startup. You will know whether it is a starter or not.
  • #11 17523822
    abart64
    Help: 271
    Rate: 633
    The thinner legs of the relay are usually a coil and it is not surprising that the thicker ohmmeter shows nothing.
    If the relay opens the ignition-starter circuit, then one thick leg should show current after turning the ignition switch to start. Pass the cable plus to the other leg and if there is a slight sparking then the brushes have run out and if it turns off the ignition or switch on the clutch.
  • #12 17524016
    tomek2875
    Rate: 38
    I think it's the ignition's fault. I had a similar problem but I left a pile of cash with electricians, which they exchanged, which even changed the battery. For me the problem was in the ignition switch but I was also immo. In general, a few staws went down the drain and the cost of the last repair is PLN 60. I also advise you to visit an electrician by calling ?
  • #13 20025190
    widmo82
    Rate: 80
    wisz wrote:
    And what turned out? I have the same
  • #14 20025376
    Wawrzyniec
    Help: 392
    Rate: 1075
    So take out the relay, ignition key and paperclip where there were thick pins from the relay. If the starter is good, it should spin.
  • #15 20025755
    kkknc
    Help: 1915
    Rate: 6709
    widmo82 wrote:
    And what do you think is the same for you. Because one symptom is different damage. What and in what order you should check the above. If you don't feel up to it, give it to someone. Although you can always deny yourself and trade for a club. They start with the battery and ending with the starter. Along the way, of course, a few things.
The discussion revolves around a starting issue with a Toyota Yaris 1 equipped with a 1.0 petrol engine. The user reports that after stopping the car, it fails to restart, with no click from the starter solenoid and no dimming of the lights when the ignition key is turned. Various potential causes are suggested, including a faulty fuse, relay, ignition switch, or starter solenoid. Users recommend checking the fuse and relay in the engine compartment, ensuring the clutch pedal is depressed during start-up, and testing for power at the starter solenoid. The user has conducted preliminary tests, confirming the fuse is intact but noting the absence of relay clicks or voltage drop during attempts to start. Further diagnostics are advised, including checking the ignition switch and possibly consulting an electrician.
TL;DR: Yaris 1.0 no‑crank with 0 clicks and "there is no click of the relay" points to a starter‑control fault, not a flat battery. Check the fuse/relay, clutch switch, ignition switch, and whether the solenoid gets power with a test light. [Elektroda, wisz, post #17523783]
Why it matters: This FAQ helps Toyota Yaris Mk1 1.0 petrol owners and DIYers quickly isolate no‑crank/no‑click faults without guesswork.
What are the most likely causes of a Yaris 1.0 that won’t crank but lights work?
Focus on the starter control path. Check the battery condition, starter fuse, starter relay, clutch start switch, ignition switch, wiring to the solenoid, and the starter/solenoid assembly. These are the standard items in Toyota’s starting system diagnostic tree for the Mk1 Yaris. Prioritize simple checks first, then test for control voltage at the solenoid. [Toyota Yaris (P1) Repair Manual – Starting System]
How do I check if the solenoid gets a control signal during start?
Use a 12 V test light. Clip to ground and probe the solenoid control terminal while an assistant turns the key to START. The lamp should light during crank. If it does not, the fault is in fuses, relay, ignition switch, clutch switch, or wiring. “Check the incandescent bulb for power to the starter solenoid during startup.” [Elektroda, mod22, post #17523808]
Where is the starter relay/fuse on the Yaris Mk1 1.0?
They are in the engine‑compartment fuse/relay box. The cover diagram identifies the ST (starter) relay position and related fuse. Verify against the lid map because trim levels can leave sockets empty. Inspect the fuse, then swap‑test or meter the relay before chasing wiring. [Elektroda, badyl666, post #17522562]
Dash lights don’t dim and I hear no click. What does that indicate?
That pattern signals no high‑current draw and no solenoid engagement. It points to an open in the control circuit, such as a failed relay, ignition switch, clutch switch, or broken solenoid feed. The thread reports bright cluster, 0 clicks, and no voltage dip under START. [Elektroda, wisz, post #17523783]
Do I need to press the clutch to start a Yaris 1.0?
Yes. The clutch interlock must read the pedal depressed before the ECU allows the START request. A failed or misadjusted clutch pedal switch prevents cranking. Check that the pedal is fully pressed and confirm the switch operation if no crank occurs. [Elektroda, CameR, post #17522508]
How do I safely bridge the starter relay to test the starter?
  1. Key ON, transmission in neutral, parking brake set.
  2. Remove the starter relay and identify the two thick power terminals.
  3. Momentarily bridge those two thick terminals with a fused jumper; the starter should spin if it is healthy. [Elektroda, Wawrzyniec, post #20025376]
Could the ignition switch be the problem on this Yaris?
Yes. Intermittent or failed ignition switch contacts can block the START signal. One owner chased the issue and ultimately fixed it at the ignition switch, spending about PLN 60. Immobilizer issues can compound symptoms, so have a competent auto electrician evaluate if basics pass. [Elektroda, tomek2875, post #17524016]
How can I test the suspected starter relay with a multimeter?
Identify the coil on the thinner pins and measure for continuity. An open reading indicates a failed coil. Apply 12 V to the coil and confirm the contact closes between COM and NO on the thicker pins. One thick terminal should get power in START. [Elektroda, abart64, post #17523822]
Relay clicks but the starter still won’t crank—what next?
If the relay actuates, bridge the relay’s power terminals. Slight sparking with no crank suggests worn starter brushes or a failed starter. If bridging cranks the engine, the control side is fine; look at clutch switch or ignition switch logic instead. [Elektroda, abart64, post #17523822]
Instrument display blanks during START yet no crank—what does that imply?
That behavior suggests the ignition switch and clutch relay are functioning, but the fault is downstream. Suspect the starter relay output, solenoid feed, or the starter itself. Continue by verifying control voltage at the solenoid and performing a relay bridge test. [Elektroda, kkknc, post #17523806]
What battery voltage should I see before and during cranking?
At rest, a healthy 12 V battery reads about 12.6–12.8 V. During cranking, avoid drops near or below 10 V. Low voltage reduces solenoid pull‑in force and can mimic control faults. Recharge or replace a weak battery before deeper diagnostics. [BU-903: How to Measure State-of-charge]
I have the same issue—what order should I check things in?
Follow a quick triage: verify battery health first, then check the starter fuse and relay. Confirm clutch switch operation, test for solenoid control power with a lamp, and bridge the relay. If those pass, inspect the starter/solenoid assembly. “They start with the battery and ending with the starter.” [Elektroda, kkknc, post #20025755]
