Procedure to Dismantle Ignition Switch, Steering Angle Sensor in Golf V 1.9, 2004 Model
golf2syncro 25455 7
  • #1 16781212
    golf2syncro
    How to dismount the ignition (body), Golf V 1.9, 2004, the steering wheel has already been removed. Now I have a problem because I do not know if I need to drill those original screws fixing the ignition switch to get the whole thing out? Ie. steering angle sensor and everything that is around the ignition switch?
    Thanks in advance for the info.
  • #2 16781381
    zibi581
    Help: 36
    Rate: 174
    I did it like that, a thin mallet, a hammer and, hitting the screws, I turned left.
  • #3 16781470
    golf2syncro
    Thanks ;) and after unscrewing these screws everything will come down from the steering column? Because I understand that it is impossible to disconnect the ignition from, for example, the steering angle sensor until it is removed from the steering column, no?
  • #4 16781665
    tadeusz03
    Rate: 14
    Here you need a lot of patience. There is no secret method only the one that the colleague described earlier. Sometimes it will unscrew quickly and without any problems and sometimes you lose patience. Nothing but good luck what I'm doing here.
  • #5 16781798
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4171
    golf2syncro wrote:
    because I understand that it is not possible to disconnect the ignition switch from eg the steering angle sensor until it is removed from the steering column, right?
    You do not need to dismantle any ignition.
    The steering column driver will be dismounted and everything you want will go down.
  • #6 16781802
    golf2syncro
    My goal is to pull the ignition switch.
  • #7 16781824
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4171
    The original screws should be treated with a cutter. Two blows and they walk with their fingers.
  • #8 16781827
    golf2syncro
    thanks, I will be on the topic tomorrow
✨ The discussion revolves around the procedure for dismantling the ignition switch and steering angle sensor in a 2004 Golf V 1.9 model. Users share techniques for removing the ignition switch, emphasizing the need for patience and caution. It is noted that the original screws can be treated with a cutter for easier removal, and that the ignition switch does not need to be dismantled separately; instead, the steering column driver can be removed to access the ignition switch and associated components.
