Deactivating Airbag Alert in VW Golf 4 (1999) 1.4 16V: Passenger Airbag Connection Issue
malimaro 8598 15
How can I activate or deactivate the passenger airbag warning on a 1999 VW Golf 4 1.4 16V using VAG/VCDS?
Use the airbag module adaptation: connect with a simple VAG KKL cable and VCDS Lite or VAG 311, then open module 15 (airbag), go to Adaptation 10, channel 01, and read the current status. A value of 1 means deactivation and 0 means activation; change it to the needed value and save it [#16604935] VCDS itself will not work with that cable, so use VCDS Lite and set the COM port with the cable connected [#16608586][#16608984] If the airbag lamp still does not go out, the fault is not just the switch setting but another problem such as wiring or the igniter, and on this car it may also be related to the driver airbag or the steering-wheel reel [#16604574][#16609191]
  • #1 16575400
    malimaro
    Rate: 159
    Hello, I have a problem that I can't solve, and it's all about pillows. Deactive airbag pops up on the display. I was at a friend's computer and told me that the passenger airbag is connected. So I deleted the passenger compartment, everything was ok. The ankle was connected to the pillow. So now I don't know where to look for this reason. This is golf 4 1.4 16v. 99r
  • #2 16575409
    spinacz
    Help: 1204
    Rate: 2654
    Cushion switch checked?
  • #3 16598779
    malimaro
    Rate: 159
    And how to activate it with vag? I know that someone will write that the topic was raised only somehow finds similar topics but the answer how to do it is not in them
  • #4 16598793
    spinacz
    Help: 1204
    Rate: 2654
    No vag should be a key switch. Provide accurate car data, year power capacity.
    I didn't notice Sora in the first post.
  • #5 16604204
    malimaro
    Rate: 159
    VW Golf 4 1.4 Benz 1999r.
  • #6 16604574
    robokop
    Help: 1763
    Rate: 6371
    There is no cushion switch there. Break in the wires, or in the igniter itself - then the light to be replaced. Because it did not deactivate in the controller itself - something caused a message. I dare say that it will be about the driver's cushion and the tape retractor under the steering wheel.
  • #7 16604587
    moto-kord
    Help: 137
    Rate: 505
    Or plugs under the seats.
  • #8 16604596
    spinacz
    Help: 1204
    Rate: 2654
    The fact I am sorry for misleading, there is no pillow switch.
  • #9 16604616
    robokop
    Help: 1763
    Rate: 6371
    In 1.4 of '99? I do not think so. Unless it's a "deluxe" version.
  • #10 16604814
    malimaro
    Rate: 159
    Well, can it just be turned off the pillow in the computer ?? I read on the forum that you can somehow turn on and on these pillows vagem or vcds, I have some cables for this Allegro is only heavy communicate with the computer, every now and then disconnects something, maybe you can recommend me some interface?
    marfur30
    Help: 138
    Rate: 386
    As for the interface, it is enough to use the most ordinary vag KK-L, and the program preferably vag 311 or vcds lite.
    We choose group 15 airbag, then 10 adaptations, channel 01 and give READ.
    The current pillow status will be displayed,
    1- deactivation
    0- activation
    So if you have 1 then you change to 0 click save and it's ready.
  • #12 16608423
    malimaro
    Rate: 159
    1- deactivation
    0- activation
    Maybe you know something about the vcds program, because I mean vagu cable, but when it comes to vcds, I get the message: port status ok, usb not found! and for China I don't know what to do to run it: /
    Added after 51 [minutes]:
    that's exactly how it looks Deactivating Airbag Alert in VW Golf 4 (1999) 1.4 16V: Passenger Airbag Connection Issue
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    VCDS will not work with this cable.
    marfur30
    Help: 138
    Rate: 386
    It must be vcds lite and you set the port with the car cable connected.
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Give the number and a detailed description of the error.
    As I remember correctly, when someone turns off the pillow, you must unplug the pillow from the pillow, otherwise the controller will report an error.
    When the pillow is deactivated, the pillow indicator flashes at the beginning and then goes out.
    If the reason is some other reason then the pillow lamp will not go out.
    Do not use anything there other than VCDS Lite because in this year there may be a driver 6Q0909605A which goes to damage by diagnosing it with something else - e.g. Polish VAG, VVTOOL or other rubbish.
  • #16 16613795
    malimaro
    Rate: 159
    I managed to activate it using vaga and everything works, thank you for the advice, I will supply vcds in the future ;)
The discussion revolves around a user experiencing a "Deactivate Airbag" alert in a 1999 VW Golf 4 1.4 16V, linked to a passenger airbag connection issue. Initial troubleshooting suggested checking the cushion switch, but it was clarified that there is no such switch in this model. Participants proposed potential causes, including wire breaks or issues with the igniter, and recommended checking connections under the seats and the driver's airbag wiring. The user inquired about using VAG or VCDS software to deactivate the airbag, leading to guidance on using VAG KK-L interface and VCDS Lite for activation. The user successfully activated the airbag using the VAG tool after following the advice provided.
