Golf 2008 1.9 TDI Ignition Switch Issues: Key Turns, Steering Wheel Unlocks, Car Won't Start
Thomasemi 16926 2
  • Ignition switch likely needs replacement
    #1 16698561
    Thomasemi
    Rate: 48
    Hello, I have been the owner of Golf 2008 1.9 tdi for two days, I intercepted the ignition until yesterday (I thought it could be the key, so I started to use the second but the same), when I came back from the store I could not start the car, the key turns to the moment of unlocking the steering wheel and I still do not want to go, I sprayed in there in 40 and nothing helps. Is it still necessary for the ignition switch to change from the Passat 2001 to petrol or to replace the steering wheels. Thank you in advance for any help answers
  • #3 16699099
    Thomasemi
    Rate: 48
    And like me howling out as the key does not turn to the end
