VW Golf VI 1.4 (2010) - Procedures for Opening Car with Discharged Battery
Jarosx9 47406 6
  • Opening a VW Golf with a discharged battery and hidden lock
    #1 13559095
    Jarosx9
    Help: 265
    Rate: 401
    There is a problem with opening a car that has been standing in the garage for several months. It's about the VW Golf VI 1.4 from 2010.
    The battery is discharged and the key fob cannot be opened a auto orig. there are no classic locks . My question is - is there any way to use this key to open this car or the hood and charge the battery or maybe you can connect the charging somewhere without opening the hood / car and open it with the remote control.
    spinacz
    Help: 1204
    Rate: 2654
    It must have a classic lock, but it is definitely hidden, look at the handle on the driver's door on the right side of the fixed handle, remove the plastic and you will be punished with the lock, just like in the Passat B6.
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    Get under the car and use the battery to connect to the starter. Weight to the kennel, plus to the thick red cable next to the starter.
  • Requests precise photo guidance for Golf VI emergency access
    #4 13559121
    Jarosx9
    Help: 265
    Rate: 401
    OK, I'll try to find something like that, or actually a friend on the phone because it's his problem.
    PS. I have to explain it to a little acquainted person, so could anyone describe more precisely on a photo as it is in this model. I don't have physical access to this car.
    PS2. Getting under the car will be a bigger problem, because the car has all the original covers on the bottom and the lever will be a problem because it is in a closed trunk.
  • #5 13559271
    autoas
    Help: 571
    Rate: 3924
    Jarosx9 wrote:
    and with the lever it will be a problem because it is in a closed trunk.
    For this operation, use a more professional jack, not the funny one ... to replace the wheels ...
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Underneath this plug is a normal insert that can be opened with a key. The arrow marks the hole in which you put the hook, screwdriver, and remove the cap.
  • #7 13561838
    Jarosx9
    Help: 265
    Rate: 401
    Thank you very much for the answers and the photo. I close the topic.
The discussion revolves around opening a 2010 VW Golf VI 1.4 with a discharged battery. The user inquires about methods to access the vehicle without traditional locks or remote control functionality. Responses suggest that a hidden classic lock may be located on the driver's door handle, which can be accessed by removing a plastic cover. Another suggestion involves connecting a battery directly to the starter from underneath the car, although this may be complicated by the vehicle's underbody covers. A helpful image link is provided to illustrate the location of the lock mechanism. The user expresses gratitude for the assistance and indicates they will close the topic.
