Scania 124l 2002: Ignition Switch Replacement - How to Remove Pin & Install New Unit
wilu2 13335 2
  • #1 16642302
    wilu2
    Rate: 59
    Hello everyone.
    Ignition switch in Scania 124l 2002. It does not reflect the key when igniting, the starter keeps spinning and the engine works, when I withdraw the key, the starter stops spinning. So I decided to replace the ignition with a new one, but to my surprise it is not that simple. It seems that the ignition switch is not screwed on, but it is secured with a pin and I do not know how to remove it and install a new one. So I am asking you for advice and thank you in advance for valuable tips.
    Best regards.
    szaman108
    Help: 199
    Rate: 912
    Only this lower electric element of the ignition switch is replaced !!! Under the paint there are small screws for a flat screwdriver, unscrew them and replace the element.
  • #3 16673126
    wilu2
    Rate: 59
    Thank you, shaman108, I replaced the lower cube and the ignition is working.
    Best regards.
