Nissan X-Trail T30 2002 2.2 dCi 136km: Hard Start, High Speeds, & Stalling - Fuel Filter & Frost
mamjuzdosc 12873 13
What can cause hard starting, high idle, stalling, and loss of power on a 2002 Nissan X-Trail 2.2 dCi after cold weather and fuel filter work, and how can the SCV/fuel system be checked?
The fault turned out to be a fuel-system/injector problem: a clogged tank pickup/strainer, a bad manual primer pump at the fuel filter, and faulty injectors [#16345532] The forum first advised checking high-pressure components such as the SCV valve, fuel rail pressure sensor, crank/cam sensors, wiring, and reading live parameters, because no stored fault codes do not exclude a mechanical or wiring issue [#16272415][#16276163][#16281207] A leak-back test showed injector 1 and 3 had almost no overflow, injector 2 had a lot of overflow, and injector 4 did not spray but still overflowed; after replacing the tips of injectors 2 and 4, injector 4 was still bad and needed replacement [#16345532]
  • #1 16262209
    mamjuzdosc
    Rate: 49
    Hello Nissan X trail t30 2002 2.2 dci 136km
    The car always fired with an arrow
    Future frosts -18 degrees and nisssan in the morning fired with an arrow after preheating the candles came warmed up a bit and drove 500-700m on the road went out, I spin a little longer than always and fired got a little spun and went out and so I chilled home a few times I changed fuel filter and I added 50ml of fuel to the fuel so that it does not freeze on 20l diesel. I warmed up the fuel lines with the heater and started it, but he turned himself on at high speed, extinguished and fired about 3-4 times, everything settled down and there was a guitar until the evening when I left the car, it was accelerating normally, it went on revolutions, etc. until it stopped and went at low speed waved a few times and went out I had to spin for a long time to start and when it fired again the same and several times I returned home while driving nothing was happening normally sped up and insight. only on idle waved and went out after a while.
    now I missed the filter and the tank with wires by connecting the fuel bubble directly to the pump and the same thing all the time, i.e. it starts burning very hard and waves and goes out.
    I wanted to check the injections but the overflows are built under the cover and how to check them I have a question I would like to check the scv valve on the pump only how to check it whether it is working or not. what could be causing these symptoms.
  • Suspected common-rail pump head failure; scan for errors
    #2 16264176
    EndrjuWiwi
    Rate: 12
    Hello, love
    I focus on damage to the high pressure pump. It can be cheap and it can be expensive, it depends what happened.
    In turn - controller, pump, injection. When you check, write what came out. Plug in to the computer, maybe it throws some errors on VAG. This is for certainty, because I bet that the head went in the CR pump. Do you have power drops? How does it fade into barren, lint? Is it smoking unnaturally? Be. we'll suggest something
  • #3 16267504
    mamjuzdosc
    Rate: 49
    Hi, I hooked up the computer for greedy mistakes, recently he started to kick in the dark, and so sometimes he lacked power so it depends when he pulled once and once pulled, pulled and suddenly such a hole in acceleration and in a moment accelerates again.
    So when waving on slow lint kennels and then such a jerk as extinguishing.
    I ordered a set of pressure gauges for checking fuel pressure, compression in cylinders, and turbo pressure. When I come to check all the pressure in the intake and fuel system. I will let you know what and how
  • #4 16267781
    EndrjuWiwi
    Rate: 12
    According to what you write, you have some faults not registered by the driver, i.e. mechanical. Smoking black means that the oil does not burn 100% and does not produce CO2, only soot. This is caused by insufficient oxygen in the combustion process. This may indicate an inappropriate injection parameter, but it is the computer that discards. This may mean a leak in the intake manifold, or a lack of light in the intake system and this will not be discarded by the computer. But between us ... I think it's a driver. Cold February and no contacts. Switch to another and check. Let me know what and how. Good luck
  • #5 16269804
  • #6 16270619
    mamjuzdosc
    Rate: 49
    Buddy above, I changed the filter immediately when I was going out while driving and besides I bypassed the fuel filter in such a way that the supply hose from the filter to the pump I took off and put it in the bubble with fuel and still the same
  • Bleed fuel system and check rail pressure and SCV
    #7 16271473
  • #8 16271565
    mamjuzdosc
    Rate: 49
    The wires are twisted into place, I am waiting for the pressure measuring kit then I will know something.
    When I put a 5l bubble it pulled it to zero in some 6-7mins.
    I unscrewed the hose from the filter supplying to the pump I put on a rubber hose
  • #9 16272415
  • #10 16276058
    mamjuzdosc
    Rate: 49
    Buddy, I hooked up the computer 5 times no errors.
    Added after 32 [seconds]:
    And how to check the scv valve? need to remove it?
  • Check engine speed, crankshaft synchronization, and SCV condition
    #11 16276163
  • #12 16280985
    mamjuzdosc
    Rate: 49
    Hello, I think I have a good lead I got OBDII CAR Autocom
    I checked the parameters when trying to start the car, the crankshaft position sensor shows from 200-210 rpm and I found the parameter: The cylinder controlling the pressure in the fuel rail and during the firing test shows 0 Mpa nwm if this is the reason, please, because it may also be that mine diagnostic computer has such a parameter but the car's computer just can't read it because I don't have something like that
  • #13 16281207
  • #14 16345532
    mamjuzdosc
    Rate: 49
    Hello, I solved the problem:
    After 1 I had a little stuffed dragon from fuel in the tank
    After 2 I had to replace the manual pump at the fuel filter because it was lame
    After 3 I took out all the injections on top, I took longer power cords from the CR strip and got rid of overflows to the plastic containers, it turned out that the 1st and 3rd injection are almost insignificant.
    2 injection atomizes but quite a lot overflows and 4 carbon does not spray but still overflows.
    after changing the tips of a 2 and 4 injection, the second stopped overflow and 4 poured overflow all the time and did not spray, i.e. I have a damaged fourth injection tomorrow I'm going to replace it with a refurbished one
The discussion revolves around a 2002 Nissan X-Trail T30 with a 2.2 dCi engine experiencing hard starting, stalling, and performance issues, particularly in cold weather. The owner has replaced the fuel filter and attempted to prevent fuel from freezing. Responses suggest potential issues with the high-pressure fuel pump, including the SCV valve, fuel pressure sensor, and crankshaft sensor. The owner has conducted diagnostics using an OBDII scanner, revealing no error codes but low fuel rail pressure. Ultimately, the owner identified problems with the fuel injectors and the manual pump at the fuel filter, leading to a plan for further repairs.
