Huawei P8 Lite WiFi Issue: Replace/Reball Module, Availability in Poland or China Only
Frizos 17037 3
  • #1 16788885
    Frizos
    I have a question about the problem described in the title. You need to replace the whole module, is it enough to reball? Will I get such a module in Poland or only China?
  • #2 16790893
    mahamalak
    Rate: 110
    If it is permanent blocking access to wi-fi then reballing will not do anything because the system is damaged, not the system connection to the motherboard itself. If the new module is only China, we will eventually dismantle it.
  • #3 17234164
    randomnick99
    This problem occurred after updating emui. Huawei support sends back to the site to replace the wifi module. The wifi itself works but only very close to the router (0.5 m), next, despite a strong signal, it sends a message about the forbidden access to the network.
  • #4 17236039
    geryon
    Help: 21
    Rate: 126
    As for the wi-fi system, we are available in Poland, and reball can not be replaced.
