Navitel e100 Navigation System: Unrecognized by Windows 7 and 10 via USB Connection
tiutesh 11100 6
  • #1 16990573
    tiutesh
    Rate: 58
    Hello forum users,
    I have Navitel e100 navigation, navigation virtually new, because it may have been used twice in the last two years, as I travel quite a lot now, I wanted to do a map update, and a meatball, no computer can see this USB navigation for me, I connected it to the station (windows 7) and on a laptop (Windows 10) and complete lack of response when connected to USB, only charging works.
    I disassembled the navigation to see if the MicroUsb socket is broken, unfortunately not, the problem lies somewhere further. Maybe someone encountered such a problem in these devices, I do not know if it is worth sending it to someone for repair.
    jajacekpl
    Help: 65
    Rate: 268
    Is there any computer response to the navigation connection? Any message about an unrecognized device?
    Check the cable - sometimes you get (e.g. in cheap chargers or power banks) only power, without a wire responsible for data transfer (in short)
    And don't connect via HUB and USB 3.0
  • #3 16990624
    tiutesh
    Rate: 58
    No reaction, no connection sound, nothing at all, no unrecognized device message.
    I checked two cables, including the original one supplied by the manufacturer with this device.
  • #4 17212174
    timoglok
    Tiutesh I have exactly the same problem; /
    Did you deal with it?
  • #5 17212208
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    Maybe I can't help but please check the USB cable on other devices. And I write as that quite recently I struggled with transmission attempts not seeing that the wires I used were intended only for chargers, i.e. simply equipped with two wires. Outside, it is no different, and yes, it does.
  • #6 17212228
    timoglok
    The cable is checked, the computer and the phone are communicating.
The discussion revolves around the Navitel e100 navigation system, which is not recognized by Windows 7 and 10 when connected via USB. The user reports that the device only charges and does not establish a data connection. Initial troubleshooting steps included checking the USB cable and ensuring it was not a power-only cable. Despite using the original cable and testing it on other devices, the problem persists with no response from the computer. Other users suggest verifying the cable's data transfer capability and avoiding USB hubs or USB 3.0 connections. A link to further assistance is also provided.
