Astra J (2011) 1.7 Diesel - Poor Battery Charging, Alternator Issue & Voltage Drop to 12.5V
kisiol 18150 18
Why does the charging voltage in a 2011 Astra J 1.7 diesel drop from about 14.8V to 12.5V after startup, even after replacing the alternator?
The Astra J uses an intelligent alternator, so the ECU can deliberately lower charging voltage after startup when the battery is considered charged; 12.5V by itself is not proof that the alternator is bad [#16790312] Check the charging voltage directly at the alternator and then at the battery clamps, and inspect/clean the alternator-to-battery and battery-to-ground cables and connections [#16789101][#16790659] The most useful test in this thread was to unplug the battery negative current/power sensor: with it disconnected, the charging voltage stayed around 14.9–15.1V for several days, which pointed to the sensor or smart-charging control rather than the alternator itself [#19939542][#20065267] If the ECU detects a battery-voltage drop, it can raise charging voltage again, so a weak battery or a faulty battery-current sensor can make the system behave inconsistently [#20065267]
  • #1 16789096
    kisiol
    Help: 36
    Rate: 469
    Hello. I have a problem with the 2011 astra J 1.7 diesel car. After firing up, the charging is around 14.8v, but after about a minute it drops gradually to 12.5v. I bought a second alternator and nothing has changed, the problem persists. Where to look for the cause. The charging indicator does not light up.
  • Check alternator and battery ground wiring first
    #2 16789101
    ^ToM^
    Help: 495
    Rate: 2940
    Start with the wires that connect the alternator to battery and battery to ground. You absolutely must have it working. It is best to disassemble, clean and assemble.
    Cheers!
  • #3 16789309
    kisiol
    Help: 36
    Rate: 469
    The masses of the alternator cable have been checked, no changes
  • #4 16789514
    Aleksander_01
    Help: 1170
    Rate: 3447
    Do you have the voltage at the output of the alternator in relation to the rear housing?
  • #5 16789516
    kisiol
    Help: 36
    Rate: 469
    Yes there is tension. The alternator charges well immediately after firing, after a while the charging starts to drop.
  • #6 16789758
    arbobo
    Help: 11
    Rate: 57
    And have you measured the charging after a longer time, e.g. 4 minutes?
  • #7 16790104
    kisiol
    Help: 36
    Rate: 469
    It is 12.5 to 13v max
  • #8 16790312
    tzok
    Help: 3177
    Rate: 6565
    The Astra J has an "intelligent alternator", ie the charging voltage is controlled by a computer. When the battery is charged, it can lower the charging voltage when stationary to reduce fuel consumption / emissions.
  • #9 16790659
    Aleksander_01
    Help: 1170
    Rate: 3447
    In my previous post "ate" the word "what" came out a stupid question and a stupid answer. Its intelligence (of the alternator) is very easy to check, put more and more load on it and the voltage should increase.
    Check the voltage directly on the alternator, then on the clamps and draw the appropriate conclusions.
  • #10 16790718
    kisiol
    Help: 36
    Rate: 469
    I read something about this intelligent alternator, except that it is probably not very intelligent. After the car is turned off, the voltage is 12.0v a little bit. After two days of downtime, there is a problem with starting the car, aku. new. Turning on full load, that is, blowing max rear light and air conditioning, still 12.5v.
  • #11 16791653
    enhanced
    Help: 964
    Rate: 884
    If there is a problem with firing after such a short time, either you have something wrong with this battery or something is eating it heavily at a standstill.
  • #12 16791703
    kisiol
    Help: 36
    Rate: 469
    Current consumption when stationary is 0.07A. So much battery after turning off it has only 12.5v. The second car of the older date is 13.5.v. Aku in working condition I changed 100% with another car.
  • #13 16791726
    arbobo
    Help: 11
    Rate: 57
    Check if the glow plugs accidentally do not heat up after firing.
  • #14 17331177
    Kingau76
    Maybe the problem with the lack of charging in the Astra IV J was solved because I have the same problem? Where to look for the cause?
  • Alternator load test shows 13.8 V under demand
    #15 19842944
    damirbarisichsplit
    You solve this problem? This problem like my problem. Maybe bad alternator?
    Ay check with Delphi diagnostic F, and l terminal. Under load after start ventilator, rear heater, ksenon light, F terminal load with 100% and voltage go to 13.8 volts. Problem its if F terminal say 100% probably alternator its bad. My problem its in idle voltage go to 12.4, after start headlight voltage go to 13.8. Maybe alternator?
  • #16 19939542
    Mareckimt
    Rate: 8
    At the ground terminal, the cables for battery charging control are connected. Unplug the plug with them from the clamp and drive a few days and check the results.
  • Disconnecting battery sensor restores charging voltage
    #17 20065267
    damirbarisichsplit
    Thanks for the tip but after disconnecting the power consumption sensor the following things happen. The charging voltage for the first 3-4 days is around 14.9 -15.1 V. After that it drops to 13.9 V in winter days, and when the ambient temperature rises above 30 C the charging voltage drops to 13.5. Except when the ECU detects a drop in battery voltage and raises the charging voltage to 14.4 V. So if you have this problem when the "smart" battery charging system is not working and you do not have a charging voltage of about 13.8 -14.9 V try disconnecting the power sensor at - battery half and will have and charging voltage (minimum but still operating voltage). When this fault was detected, the consumption sensor was replaced, the alternator was replaced and there was no change. I doubt the body computer but I only doubt it because this problem has taken up enough of my time
  • #18 21581468
    aca130kg
    >>20065267 @damirbarisichsplit jel si resio problem? Sve iste simptome imam.
  • #19 21582149
    damirbarisichsplit
    >>21581468 Sve sam objasnija u ovom postu iznad. Pažljivo ga procitaj. A Astru sam proda prije 3 godine. Poz.
The discussion addresses a charging issue in a 2011 Opel Astra J 1.7 diesel where the alternator voltage initially reads about 14.8 V after startup but gradually drops to around 12.5 V within minutes. Replacing the alternator did not resolve the problem. Key diagnostic steps include checking and cleaning the alternator-to-battery and battery-to-ground wiring, verifying voltage at the alternator output relative to its housing, and measuring voltage under load. The Astra J features an intelligent alternator system controlled by the vehicle's computer, which modulates charging voltage to optimize fuel consumption and emissions. However, this system can cause lower voltage readings at idle or stationary conditions. Persistent low voltage and starting difficulties after short downtime suggest possible battery issues or parasitic drain, though measured current consumption at rest was low (0.07 A). Disconnecting the battery power consumption sensor temporarily restored higher charging voltages (up to 15.1 V), but voltage still dropped with temperature changes, indicating potential faults in the sensor, body computer, or alternator control circuitry. Diagnostic advice includes using Delphi diagnostics to monitor alternator terminals under load and testing the effect of disconnecting the battery charging control cables. The problem remains unresolved, with suggestions pointing toward faults in the intelligent charging system components rather than the alternator itself.
TL;DR: Many Astra J 1.7 CDTI owners report charging falling from 14.9–15.1 V to ~13.5–13.9 V; “disconnect the power sensor at - battery” as a diagnostic. [Elektroda, damirbarisichsplit, post #20065267]
Why it matters: This FAQ helps Astra J owners diagnose low charging voltage, parasitic drain, and smart-alternator behavior without guesswork.
Why does my Astra J drop from ~14.8 V to ~12.5–13.0 V after a minute?
Your car uses a smart alternator. The ECU lowers voltage once it thinks the battery is replenished, especially at idle, to reduce emissions. This behavior can look like a fault, but it is part of the strategy. Add electrical load to see if voltage rises again. [Elektroda, tzok, post #16790312]
Is 12.5–13.0 V at warm idle normal on this car?
Owners reported 12.5–13.0 V after a few minutes. That aligns with the load-dependent strategy. Apply lights, blower, and rear defogger; voltage should increase if control works. “Put more and more load on it and the voltage should increase.” [Elektroda, Aleksander_01, post #16790659]
How do I quickly test the charging system response to load?
  1. Measure voltage at the alternator B+ and at the battery clamps.
  2. Switch on headlights, blower, and rear defogger.
  3. Confirm voltage rises and that alternator and clamp readings are close; large differences suggest wiring/ground issues. [Elektroda, Aleksander_01, post #16790659]
What is the battery current sensor and why do people unplug it?
It’s a sensor on the negative clamp that reports battery current to the ECU. If unplugged, many owners see a stable, higher charging voltage as a fallback. One report: 14.9–15.1 V for several days, then ~13.9 V in cold, ~13.5 V in heat. [Elektroda, damirbarisichsplit, post #20065267]
My battery reads 12.0 V after shutdown and struggles to start—what does that mean?
A user reported 12.0 V after shutdown with hard starts two days later. That resting voltage is low and indicates the battery is undercharged or being drained. Address charging control and parasitic draw before replacing more parts. [Elektroda, kisiol, post #16790718]
What parasitic draw did owners measure, and is it significant?
One owner measured 0.07 A at rest. That equals about 1.68 Ah per day, which can weaken starts if trips are short. Track down modules that stay awake or test by pulling fuses. [Elektroda, kisiol, post #16791703]
Could stuck-on glow plugs cause low voltage or poor charging?
Yes. If glow plugs keep heating after start, they add heavy load and mask charging. Check for post-start current draw on the glow circuit as an edge case. [Elektroda, arbobo, post #16791726]
I replaced the alternator and the issue remains—what next?
Inspect and service the main charge cable, battery positive lead, and grounds. Disassemble, clean, and refit connections between alternator, battery, and chassis. Poor connections can mimic alternator failure. [Elektroda, ^ToM^, post #16789101]
How do I compare alternator output to battery terminal voltage correctly?
Measure directly at the alternator B+ to the alternator housing, then at the battery clamps. If alternator voltage is healthy but the battery reading is lower, suspect cable resistance or grounds. [Elektroda, Aleksander_01, post #16790659]
What does “F terminal 100%” in Delphi diagnostics indicate?
An owner saw F terminal at 100% under load with voltage rising to 13.8 V. That suggests the ECU requests full alternator output. If voltage still sags at idle, the alternator or control path may be weak. [Elektroda, damirbarisichsplit, post #19842944]
Is unplugging the current sensor a permanent fix?
It’s a diagnostic workaround. One user replaced the sensor and alternator with no change; unplugging restored usable charging but varied with temperature. Treat it as a clue, not a final repair. [Elektroda, damirbarisichsplit, post #20065267]
What if the charging light never comes on, yet voltage is low?
Smart systems can reduce voltage without triggering the lamp. Verify by loading the system and measuring at alternator and battery. If voltage fails to respond, investigate wiring, grounds, sensor, or alternator control. [Elektroda, tzok, post #16790312]
Will driving with the sensor unplugged cause problems?
Reports show stable operation with higher baseline voltage, but it is a fallback. The ECU loses precise state-of-charge data, and charge levels vary with ambient temperature. Restore sensor feedback after diagnosis. [Elektroda, damirbarisichsplit, post #20065267]
Someone asked if the original case was solved—what’s the takeaway?
Participants reported that cleaning cables, load-testing, and trying the sensor unplug test clarified faults. One owner later sold the vehicle; the thread documents what improved charging during ownership. [Elektroda, damirbarisichsplit, post #21582149]
