Opel Astra G 1.6 16V 1998: Starter Replacement & Battery Recharge Issues - Ground Connection
Brayananos 16083 6
  • #1 16436828
    Brayananos
    Hello. I have a problem. I have Opel Astre G 1.6 16V 1998. The starter stopped and I replaced it with a new one. Everything worked but suddenly stopped spinning today. I turned the ignition switch, the run light, etc. I turned on the ignition switch, everything went out, I fired up, he fired right away.
    I got home and decided to recharge the battery. Charged I twisted and again nothing but now the controls did not go out and so far.
    I have cleaned the battery terminals and checked the ground which can still be the cause ?? I am asking for urgent help !!! Regards Brayananos.
  • #2 16436858
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4171
    The ignition switch can be checked.
    Brayananos wrote:
    I exchanged for a new one.
    New, new or new used?
  • #3 16436964
    Brayananos
    Used but from a reliable source and after careful checking. He is on new brushes, etc. (A colleague has deleted the car and regenerated a few days earlier) so I consider him new.
    The ignition switch has been checked.
  • #4 16436972
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4171
    Appears + 12V for the electromagnet after turning the ignition key?
  • #5 16437159
    Brayananos
    That's how it goes
  • #6 16437229
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5049
    If it comes and check it correctly then look for a problem in the starter or the lack of its power supply.
  • #7 16437269
    Brayananos
    Okay, thanks for the hints I greet
✨ The discussion revolves around a 1998 Opel Astra G 1.6 16V experiencing starter replacement and battery recharge issues. The user replaced the starter, which initially worked but then failed again. After recharging the battery, the vehicle showed no signs of power, prompting the user to check battery terminals and ground connections. Responses suggest verifying the ignition switch and ensuring proper voltage supply to the starter. The user confirmed the ignition switch was checked and the starter was sourced from a reliable provider with new components.
