Opel Astra 1.6 - 95: Battery Charging Lamp On, Voltage Over 15V - Delco Remy GM Alternator Issue?
michal75 63992 11
Why does my Opel Astra alternator leave the charging lamp on while battery voltage rises to 15–16.5 V, even after replacing the voltage regulator?
The excessive voltage is most likely caused by the regulator sensing too little voltage because of a poor contact, ground, or connection, so it drives the rotor excitation too hard [#927883] Check and clean the regulator’s ground, the alternator-to-battery cable, battery clamp, and all terminals, then tighten them securely [#921334] A faulty replacement regulator is also possible, so verify that the second regulator is actually good [#921334] Damaged rectifier diodes generally should not cause overvoltage, although the diode assembly and wiring should still be checked [#920922] Do not continue driving with 15–16.5 V, because it can boil the battery, shorten bulb life, and damage vehicle electronics [#921334]
  • #1 920826
    michal75
    Hello, I have a problem, the battery charging lamp on the alternator is on, the voltage is about 15 V and the battery is similar (low speed) with the load on the lights and increasing the speed, the voltage on the battery increases to about 16.5 V. What can it be? I changed the voltage regulator and the symptoms are the same, so I put in the old (I will spend less) diodes in the alternator like oki, but tomorrow I will remove them and check each one separately, but how is it not what could be the cause? Save me
    Alternator - Delco Remy GM
    I have an Opel Astra 1.6 - 95
  • #2 920922
    Zbysław
    Help: 78
    Rate: 73
    Damaged diodes should not raise the voltage.
    Are you sure of the gauge?
    Check the connections of the alternator-battery cables, with insecure contact, the voltage may increase.
    In order for the lamp to go out, the positive voltage must be the same on both sides (from the excitation diodes and from the positive diodes).
    The symptoms indicate that the excitation LEDs are working, but no voltage is reaching the lamp. Check the wires, contacts (corrosion, oxidation).
  • #3 920952
    axxx
    Home appliances specialist
    Help: 376
    Rate: 1720
    Oh, Zbyslaw, something wrong, the lighting of the indicator means no charging,
    and you are overcharged, and the light is on.
    If the voltage is too high and the charging current is too high, the electrolyte will boil and the water will evaporate. Is your battery not short-circuited?
  • #4 920974
    Zbysław
    Help: 78
    Rate: 73
    The indicator light is not a good test of charging, it may not light up both when the alternator voltage is too low and too high, it may also light when the voltage is not being charged and when the voltage is too high.
    I do not know if you understood correctly, the indicator does not indicate how the altenator is working, it only informs that the alternator produces some sem (if it goes out).
  • #5 920993
    axxx
    Help: 376
    Rate: 1720
    The indicator light is on when there is no charging, in other situations it may light up depending on the engine speed. In your situation, the regulator is definitely to blame because it is responsible for maintaining the appropriate voltage. One more thing, which measuring device did you use?
  • #6 921012
    michal75
    As for the meter, I am sure that it is good (I had it from the electrician and he himself measured all the things with the alternator removed - he checked the diodes - but tomorrow he will take them and take them out of the alternator and check them once more), I check the wires, of course, but I've already watched them and it looks ok
  • #7 921017
    Zbysław
    Help: 78
    Rate: 73
    to axxx
    and Michala is supercharged and the light is on, what's your colleague?
  • #8 921019
    michal75
    and you have overcharging and the indicator light is on.
    As for the battery, so far it works, it is a self-service bosch and even has a green dot, that is, everything is ok, and on this lit lamp from charging I drove about 150 km because it happened to me on the road, at least I think so, but I certainly did 150
  • #9 921039
    michal75
    axxx wrote:
    The indicator light is on when there is no charging, in other situations it may light up depending on the engine speed. In your situation, the regulator is definitely to blame because it is responsible for maintaining the appropriate voltage. One more thing, which measuring instrument did you use?
    as for the siwecenia the indicator is so that when starting the engine and working at low speed, it blinks a little and does not shine too much, but when I turn on the switch or raise the speed, I give it normally - it lights up, I replaced the regulator with a new one, but the effect was there, so I put it back in old because why pay PLN 100 for it (it cost so much), and the meter was a standard multifunction A, V, etc., I do not know the details
  • #10 921334
    Zbysław
    Help: 78
    Rate: 73
    I do not recommend driving with such a high voltage in the installation, there are irreversible changes in the battery, you shorten the life of the bulbs, and the worst thing is that some electronics may fail.
    Was the second regulator really good?
    If the alternator-battery cable is OK (unscrew, clean, lubricate, twist - also the clamp), then the damage should be in the regulator or its vicinity (e.g. no mass on it).
    When the voltage is too high, the regulator cuts the excitation current from the rotor and connects the second brush also to the ground (the rotor then has only residual magnetism and the voltage drops).
  • #11 927883
    Staszek z Chełma
    Level 19  
    Help: 19
    Rate: 56
    There is another possibility that the voltage regulator contacts badly, it reads that the voltage is too low and gives the excitation current to the maximum.
  • #12 2341804
    michcio997
    Level 19  
    Help: 7
    Rate: 21
    rather you do not have walnieta one diode
    it will be felt when you streak and the lights shine brighter on the doormat moves faster
    costs PLN 120 3 dioty + regulator it is recommended to replace this and that + buckets, preferably
    Moderated By kosmita:
    a warning for answering topics from two years ago, and for committing a large number of spelling mistakes
    https://www.elektroda.pl/rtvforum/viewtopic.php?p=2351799#2351799
    Entry made on: 2006-02-26 at: 22:14
The discussion revolves around an issue with an Opel Astra 1.6 (1995) where the battery charging lamp is illuminated, and the voltage readings exceed 15V, reaching up to 16.5V at higher engine speeds. The user has replaced the voltage regulator but continues to experience the same symptoms. Responses suggest checking the alternator-battery connections for secure contact, as poor connections can lead to voltage fluctuations. Some participants indicate that the indicator light may not reliably reflect the alternator's performance, and emphasize the importance of ensuring the voltage regulator is functioning correctly. There are concerns about potential damage to the battery and electrical components due to overcharging. Suggestions include checking the diodes in the alternator and ensuring proper grounding and connections.
