[Solved] LTE internet speed drop; Huawei E5573 modem + Dual LTE / 4G Antenna
Gotrek1994 5283 7
  • #1 16791130
    Gotrek1994
    for a week I have a problem with LTE internet with no data limit in the PLUS network, namely the download and upload speed decreased from 20Mb / s download to 4Mb / s and 10Mb / s to 2Mb / s upload. The equipment I have is a Huawei E5573 modem and a Dual LTE / 4G 15dBi antenna. The signal strength is 3 LTE bars and the frequency is set rigidly in the 1800Mhz band in the E5186 Toolbox program.
    I have about 6-7 km to the nearest BTS, it is BTS Wólka Brzezińska - gm. Goworowo
    The steps I have taken are:
    - device reset
    - I tried different antenna settings
    - and checked that nothing was damaged during the recent storms.
    Observations:
    when I turn on any speedtest, it shows the speed of 20-30Mb / s at the beginning, then it drops systematically to 4-5Mb / s, the same happens with sending, but here the speed drops from 10-12Mb / s to about 2-3Mb / s.
    This internet does not allow me to work and hence the question for you, dear forum members, what should I do to return the internet to its original form.
    Best wishes :)
    Michal_WWL
    Help: 76
    Rate: 284
    Maybe you actually exceeded the basic transfer package in Plus? For me it is the same, I have the option "no data limit" and after exceeding the contracted 30GB, the speed drops to 5Mb / s.
  • #3 16791401
    Gotrek1994
    Thank you for your answer, I have 50GB of the basic package and I will not use it, I have about 60 Mb / s download and about 15 Mb / s upload, 20Mb / s download speed and about 10Mb / s upload after using these 50GB. Is it possible that Operator / BTS deliberately restricts me?
    Michal_WWL
    Help: 76
    Rate: 284
    I have such a provision in the contract about the decrease in speed after exceeding the basic package.
    matek451
    Help: 4352
    Rate: 5808
    Of course, Plus, after exceeding the data limit, it cuts the speed for the first time and then again, just like you do, for example 5 / 2Mb / s. Consequently, it can even use a 0.5Mbps funnel if you continue to collect a lot of data.You have 50GB at max, then about 100GB at 20 / 10Mbps, then 5 / 2Mbps at about 170GB may be 0, 5 / 0.2 Mb / s up to 32Kb / s. This is the operation of the FUP, with no FUP rules whatsoever, and this is indicative. Plus, nothing is guaranteed and the funnels are allocated by I see them. This is allowed by their regulations under which you signed. There is no LTE internet in Plus with no data and speed limits.
  • #6 16791864
    Gotrek1994
    Thank you for the answer, since we have already established what is happening, now maybe you have an idea how to restore the previous speed?
    Michal_WWL
    Help: 76
    Rate: 284
    Just wait until the end of the billing period.
  • #8 17228747
    Gotrek1994
    The problem disappears with the new data packet. PLUS are scurlesins :)
The discussion revolves around a user experiencing a significant drop in LTE internet speeds on the PLUS network while using a Huawei E5573 modem and a Dual LTE/4G 15dBi antenna. Initially, the user reported download speeds of 20Mb/s dropping to 4Mb/s and upload speeds from 10Mb/s to 2Mb/s. Despite having a no data limit plan, responses indicated that the user might be affected by the operator's Fair Usage Policy (FUP), which reduces speeds after exceeding a certain data threshold. Suggestions included waiting until the end of the billing period for speeds to normalize, as the issue typically resolves with the renewal of the data package.
