Touareg 2006: Replacing Parking Light Bulb in VW Torsion Bixenon Headlights with Cornering Light
angelus866 9897 4
  • #1 16791139
    angelus866
    I warmly welcome,
    I have had a VW Touareg from 2006 for a few days. I would like a hint on how to replace the parking light bulb. The headlights are torsion bixenons, with cornering light. I took out the headlight without any problems. How do I replace this bulb? I don't have any rubber plug to get to it. I have the only rubber plugs completely on the other side and one on the bottom, but none of them gives access to this bulb. Do you have to disassemble the entire rear part of the headlamp housing, or is there a trivial way I do not notice?
    Thank you in advance for the hints and best regards,
    Marcin
  • #2 16791389
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    And because of this round flap from above it will not work?
  • #3 16791875
    angelus866
    Well, it can't. Tomorrow I'll pull out the spotlight and take pictures. There is no access to this bulb. But as I say tomorrow I'll take out the reflector, take pictures and put it in here, maybe it'll help.
  • #4 16795359
    Level 37  
    Help: 211
    Rate: 1014
    And the instruction manual says nothing about replacing this bulb?
  • #5 16795365
    angelus866
    Hello, case solved. The headlight is in the facelift version (black center), if someone has a similar problem, do this:
    1) We take out the reflector
    2) Unscrew the 4 screws on the back of the reflector, removing the cover
    3) If someone has small hands, he can easily pull out the bulb (press on the holder and pull it towards you)
    4) Put the new bulb in, press the socket into the headlight, tighten 4 screws
    5) We put in the reflector and enjoy the replaced bulb
