[Solved] VW Golf 6, 1.4tsi, 2009: Can Xenon Assembly Be Installed? Mounting Possibility
becy6 4398 10
Can I retrofit xenon headlights to my 2009 VW Golf 6 1.4 TSI?
Yes, but it is not a simple plug-in swap; you need a complete original bi-xenon retrofit. The thread says you need headlight washers and ride-height/level sensors on the suspension to control beam angle [#16753149][#16753452] You also need to replace the whole headlamp units with original bi-xenons, then code everything with VCDS [#16753452] One reply adds that the AFS xenon control unit is also required because it handles leveling and lens twisting, and that the BCM/AFS software must match the retrofit [#16927950][#16928064] Another user notes that professional retrofit companies can do it factory-like, and that even with OEM parts the cost can be high [#16927971][#16928032]
  • #1 16753093
    becy6
    Rate: 51
    It is possible to mount a xenon to my golf 6
    Moderated By T5:
    3.1.15. Do not ask immediately on the forum if you have not checked anything yourself or have not attempted a self-diagnosis. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should include the brand, model and a brief description of the fault. One week of vacation.
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    For xenon, you need headlight washers and tilt sensors on the rocker arms that will regulate the beam angle. And you probably don't have such ;)
    Such regulations, but you probably passed an opposite car more than once, which made you very blind. Yeah, he probably had some xenons.
  • #3 16753268
    becy6
    Rate: 51
    I have the sprayers for lefrectors and they work
  • #4 16753452
    kozik20l
    Help: 9
    Rate: 16
    You need to change the entire lamps to the original bixenon for this ankle adapters, add position sensors on the pendants as a colleague wrote and code everything with vcds and we have everything legally
  • #5 16927950
    BRUNO60
    It's not everything . You need to add the AFS xenon driver which is responsible for the leveling and twisting of the lenses.
  • #6 16927953
    kortyleski
    Help: 957
    Rate: 3860
    becy6 wrote:
    lefrectors
    What is this wonder?
    My advice: go to the showroom and ask about the possibility of retrofitting your car with xenon HEADLAMPS. It may not be cheap, but you will not blind others. And if the bell rings, the receipts will be fine.
  • #7 16927971
    BRUNO60
    kortyleski wrote:
    becy6 wrote:
    lefrectors
    Bad advice. Unless someone has a bag of cash. There are companies that professionally install XENON lamps and bills, and they do it like a factory. The cost of such assembly in relation to the ASO is about 50-70% cheaper, e.g. http://vwtech.pl/
    ASO will most likely say that it cannot be. And if possible, the price will fly into space.
  • #8 16928032
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    BRUNO60 wrote:
    Bad advice
    Ok, what's your budget for it, it will explain a lot and we will write what and how?
    The floodlights alone in the stimulant cost 2-3 thousand set depending on the condition.
  • #9 16928064
    BRUNO60
    Strumien swiadomosci swia wrote:
    BRUNO60 wrote:
    Bad advice
    I only replied that he was wrong. I've already installed one such set of BI-Xenons at my colleague Mk6 and now I have a second set for my Mk6 and I know exactly what to put on, how to make a beam, what parts are needed, what SW should be AFS and what should be the BCM and how many costs, hence I wrote that prices in ASO for such a service go into space. Everything can be bought ori and after assembly it is and works as factory
    Help: 1405
    Rate: 6430
    That's ok, contact the author of PW.
  • #11 17145744
    becy6
    Rate: 51
    I close the topic
The discussion centers around the feasibility of installing xenon headlights on a 2009 VW Golf 6 (1.4 TSI). Key requirements for installation include headlight washers, tilt sensors for beam angle regulation, and the replacement of standard lamps with original bi-xenon units. Additionally, an AFS xenon driver is necessary for lens leveling. While some participants suggest consulting a dealership for retrofitting, others recommend professional installation services that are more cost-effective than dealership prices. The total cost for the xenon setup can range from 2,000 to 3,000, depending on the condition of the components. Proper coding with VCDS is also essential for legal compliance.
