KUNFT 40CG160014 TV Constantly Restarting: USB Pen Fix & How to Turn Off/On Properly
querij 12396 7
  • #1 16794753
    querij
    Help: 42
    Rate: 227
    Copy the file to a usb pen, turn off the tv, insert the pen and turn on the tv
    • SISEU23X8M.zip (5.3 MB) You must be logged in to download this attachment.
  • #2 17731128
    fabiob
    i can't get my tv united led22b16 to work, it always restarts
  • #4 20395486
    hassanelektro
    Rate: 26
    I have the same prb
  • #5 20395779
    querij
    Help: 42
    Rate: 227
    For which device?
  • #6 20453116
    pedrogama2
    >>16794753
    I have a tv just like that that faulted the motherboard, so i bought another board but from an hisense tv, the board is exactly the same but it now shows hisense upside down and for just half a second. i tried to put your dump in a usb drive and turning on the tv but did nothing diferent. do i need to do something else? thanks
  • #7 20453580
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    A pen tem que estar formatada em fat32
  • #8 20453585
    querij
    Help: 42
    Rate: 227
    The pen must be formatted in fat32. For the software to start updating, the device must be turned on. The led should blink slowly while updating and faster when the software is updated. disconnect from the mains and remove the pen.
The discussion revolves around the KUNFT 40CG160014 TV, which is experiencing constant restarting issues. Users suggest using a USB pen drive to update the TV's software as a potential fix. It is emphasized that the USB pen must be formatted in FAT32 for the update process to work. The update procedure involves turning off the TV, inserting the USB pen, and then powering the TV back on. Users also mention that the LED indicator should blink slowly during the update and faster once completed. There are mentions of similar issues with other brands, including United and Hisense, with some users sharing their experiences with motherboard replacements.
