How to recognize the network voltage by the appearance of a power pole?
kamil19629 43305 11
How can I determine the exact voltage of a medium-voltage power pole from its appearance?
You usually cannot determine the exact rated voltage from the pole’s appearance alone; the line is medium voltage, and in Poland it is most often 15 kV, but 20 kV and 30 kV also exist, so only the local utility (ZE) can confirm the exact value [#16796143] [#16796369] For design purposes, the difference in minimum external insulation distances between 15 kV and 30 kV is only about 20 cm, so the official line data matters more than visual guesswork [#16796768] If you need the setback or protection zone, check the local spatial development plan and the technological strip of the line at the municipality/town office [#16796768] You can also send the utility a photo of the pole together with its pole number and ask them to identify the line [#16796182]
  • #1 16796101
    kamil19629
    Hello, I am an employee of an architectural office and I have a problem, namely the pole of the investor passes probably a medium voltage pole but needs information about its exact voltage. Will there be a specialist who will decipher them after removing the pole?
  • #2 16796143
    Maciek051996
    Help: 99
    Rate: 300
    Picture wrongly added but it is medium voltage line.
  • #3 16796158
    kamil19629
    I know that much, but I could use his tension, because the distance in which a building can be erected depends on it.
  • #4 16796160
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Eat after the line to the station.
  • #5 16796161
  • #6 16796175
    krakarak
    Help: 681
    Rate: 1846
    Adamcyn wrote:
    And how will the fence be on the way? :)
    It will take a photo with your smartphone and throw it on the electrode with a question.
    Not that I clung, but "tension does not flow over the pole" ...
    I think a colleague has nothing to do with the Design Office.
    A professional goes to the power plant or calls to get the correct answer.
  • #7 16796176
    kamil19629
    The problem is that the place of investment is quite distant from the place of my work and it rather falls off, I still have markings on the plate but it's supposedly only the ordering of poles
  • #8 16796182
    krakarak
    Help: 681
    Rate: 1846
    @ kamil19629 imagine there are telephones and you can talk and discuss things at considerable distances. Do you think that ZE doesn't know what lines it has on its territory? If you think so, send this picture together with the pole number.
  • #9 16796284
  • #10 16796369
    masonry
    Level 30  
    Help: 106
    Rate: 832
    This is the MV line.
    In Poland, the most common is 15kV, but there are 20 and 30 kV.
    You can only find out exactly in the proper ZE.
  • Need exact voltage from utility and local plan office
    #11 16796768
    zbich70
    Help: 1171
    Rate: 6668
    But why do you need such accuracy in determining the rated voltage?
    For voltages between 15 and 30kV, the difference in minimum external insulation distances is only 20cm.
    First, let the author visit the appropriate town / commune office with a query about the local spatial development plan and the technological strip of the given line.
    Adamcyn wrote:
    Now I noticed that Kamil is not from here.
    Where's your Cherna?
    Well, the gugle sends me to Bulgaria ... :D
The discussion revolves around identifying the voltage of a medium voltage (MV) power pole, with the original poster seeking specific voltage information for construction planning. Responses indicate that the pole is likely part of a 15kV line, common in Poland, but could also be 20kV or 30kV. Participants suggest contacting the local energy provider (ZE) for precise voltage details and mention that the difference in insulation requirements between these voltages is minimal. The author expresses difficulty in accessing the site due to distance but is advised to utilize available communication methods to obtain the necessary information.
TL;DR: You can’t read exact line voltage from a pole’s look; for 15–30 kV the clearance difference is only 20 cm. “First, check the local plan and the technological strip.” [Elektroda, zbich70, post #16796768]
Why it matters: Architects, surveyors, and investors need safe setbacks and an official voltage before designing near power lines.
How can I tell the exact voltage just by looking at a power pole?
You can’t. Visual features suggest medium voltage, but they don’t prove 15, 20, or 30 kV. Confirm with the utility. [Elektroda, masonry, post #16796369]
Who can officially confirm the line’s rated voltage?
The competent Distribution System Operator (ZE) for that territory. Contact them and request the line’s rated voltage. [Elektroda, masonry, post #16796369]
Does 15 kV vs 20/30 kV change the building distance a lot?
No. For 15–30 kV, the difference in minimum external insulation distances is about 20 cm, not meters. [Elektroda, zbich70, post #16796768]
What should an architect or investor do first near an MV line?
Visit the commune or town office. Ask for the local spatial plan and the line’s technological strip requirements. [Elektroda, zbich70, post #16796768]
How do I contact the utility and what info helps?
Call the ZE, provide the pole number, and share a clear photo and location. “A professional goes to the power plant or calls to get the correct answer.” [Elektroda, krakarak, post #16796175]
My project site is far away—can I sort this remotely?
Yes. Email the ZE with the pole number and photo; discuss by phone to obtain the official voltage. [Elektroda, krakarak, post #16796182]
How do local plans affect where I can build near MV lines?
They define a technological strip—protected width and clearances that govern setbacks and permissible works. [Elektroda, zbich70, post #16796768]
Quick 3-step: How to check planning constraints for a line
  1. Go to the commune office.
  2. Request the spatial development plan.
  3. Ask for the technological strip parameters for that line. [Elektroda, zbich70, post #16796768]
Can I just follow the line to a substation to figure out the voltage?
Don’t rely on that; obstacles and layouts vary. Call the ZE instead for an authoritative answer. [Elektroda, krakarak, post #16796175]
What is “medium voltage (MV)” in distribution?
MV is the distribution range between low and high voltage; typical networks use about 10–30 kV. “How to determine voltage of power lines”
