Minimum Distance Required Between 20kV Medium Voltage Line and Building for Permit
jacko40 57530 30
What is the minimum distance between a 20 kV medium-voltage line and a building required to get a building permit?
The thread does not give one exact meter value; it says the required setback is defined by construction law, so you need to check the legal distances for a residential building and the exact route of the line on the plot [#5056792] If the line or pole crosses the plot, first verify whether there is an easement or any restriction on ownership in the land documents, because that can determine what you can do [#5053557][#5053712] If there is no easement and less than 30 years have passed since the pole was erected, you may be able to demand its removal, but the utility may try to charge the owner for reconstruction costs if the matter is handled after purchase [#5053557][#5056792] Several replies warn that even if buying is possible, the plot may be hard to build on, so it is worth asking the power utility (ZE) directly before deciding [#5058553]
  • #1 5051219
    jacko40
    Hello forum members ... maybe any of you had a similar dilemma; I can buy a building plot, but a 20 kv medium voltage line passes through this plot .... I have a question what is the minimum distance of such a line from the building to obtain a building permit ..
  • #2 5053200
    PAblo241
    Help: 12
    Rate: 11
    I do not know what the distance is, but you can demand that the pole be removed from your plot from the power industry.
  • #3 5053557
    prez8s
    Help: 69
    Rate: 334
    Maybe, if there is no easement in the papers for ZE and no more than 30 years have passed since the post was erected.
  • #4 5053689
    WERWOLF81
    If you love your children do not buy, the harmfulness of the em field is beyond doubt, and it may take several years to remove the pole from the plot.
  • #5 5053712
    Narcyz2
    Help: 7
    Rate: 16
    LInia SN is to have restrictions. Check if the previous owner had a restriction on the ownership right. If he had any, everything will fall on your pocket
    Narcissus 2
    Added after 5 [minutes]:
    I am adding the 50 Hz voltage effect, don't let it scare you, because it won't be there.
    Narcissus 2
  • #6 5055837
    Madrik
    Help: 627
    Rate: 1191
    WERWOLF81 wrote:
    If you love your children then don't buy, the harmfulness of the em box is beyond doubt.
    Ooooh ... :D And where does your colleague get such data? For the last 20 years, the largest research institutes have been trying to determine whether this field is harmful to living organisms at all, and your colleague already knows? Does your colleague know what the strength of this field is near such a line? And what is this harmfulness? Hair is falling out? Will the worms lie in your head? Or maybe dandruff attacks insidiously?
    There are other reasons for avoiding building a house on such a plot of land. If it is not possible to remove the line from the plot, in the event of a failure, there is a threat to the lives of people on the plot.
    If necessary, the ZE simply packs up on the plot with heavy equipment and repairs the line.
    Same attractions.
  • #7 5055877
    WERWOLF81
    Well, I do not know if my colleague looked at what research results were obtained in independent studies and those commissioned by various companies and concerns (and it is not about a great conspiracy theory but about facts, and if the field is harmless, considering a colleague as ignorant is not an exaggeration - they always teach on politbud that safety is the most important thing, not scientists' arguments).
    PS "Is a line break associated with an earth fault safe for the user of the plot in question?"
  • #8 5055884
    Melonson
    When the line breaks, you need to keep the legs tied together and not to take steps because then the so-called step tension increases
  • #9 5055888
    WERWOLF81
    Rightly so, but when you leave the house, do you always intend to look at the pole?
  • #10 5056625
    Madrik
    Help: 627
    Rate: 1191
    You can always make an insulating rubber sidewalk and neon curbs.
    When the garden is nice, i.e. the lamps are lit, it is better not to go out ...
    :D
    And let's not go crazy with research. The results usually come out as desired by the client. Same as with cigarettes - they are said to cause cancer of the lungs and other organs.
    Cigarettes, people in Europe have known for over 600 years. In America, the natives have smoked for several thousand years. And they don't have any cancers. Even before World War II, lung cancer was a sensational medical case. Until the 1970s, nobody cared about it. When the cancer "epidemic" began, cigarettes were found guilty. Meanwhile, cancer is also common among non-smokers. But no one is talking about it anymore. He is guilty - why look for a real one?
    It is similar with the electromagnetic field. Until someone proves to me that the rat dies after a week of living under the power line, I'm not going to worry about it.
  • #11 5056792
    koyot_77
    Hello!
    The troubles themselves are when we have a pole or a line goes over the plot. firstly, removing it is not simple and cheap, the power industry will not do it when we fail, they will write a collision removal agreement with us and charge the owner of the plot with the full costs that result from the reconstruction of the line, i.e. design, cost estimate, execution and finally they have to be handed over to each other a section of the line converted free of charge into its property ...
    The construction law describes in detail the distance from such lines to build a residential building.
    I advise against buying such a plot, now it is known why these plots are cheap :)
    Recently I met with a guy who bought a plot of land and only then started to fight for the removal of the MV line.
  • #12 5058553
    stomat
    Help: 257
    Rate: 1982
    And I do not advise against it. At least without thinking. It all depends on how the line runs in relation to the plot. What is that line. How much space is there to build despite the lines? Perhaps the line will be closed or rebuilt in the next several to several years. Maybe there is an opportunity to pick up a nice plot of land cheaply, maybe not, but it is worth considering.
    It is even worth considering moving the pole at your own expense (if there is where to move it). I would suggest taking a closer look at the matter, talking to someone from "ZE", asking here and there.
  • #13 5059421
  • #14 5060769
    krzychol66
    Help: 57
    Rate: 125
    WERWOLF81 wrote:
    Well, I don't know if my colleague looked at what research results were obtained in independent studies and those commissioned by various companies and concerns (and it is not about a great conspiracy theory but about facts, and if the field is harmless, considering a colleague as ignorant is not an exaggeration - they always teach on politbud that the most important thing is security, not scientists' disputes).
    Can you ask for relevant quotes or references to the mentioned research?
    Of course, I am interested in the harmfulness of the 50 Hz electromagnetic field radiation, and not the potential danger of electric shock in the event of an earth fault or to the MV line building.
  • #15 5062708
    WERWOLF81
    www.kraj-cech-rad-bio.pl/index_pliki/page0016.htm - 28k
  • #16 5063645
    stomat
    Help: 257
    Rate: 1982
    Well, the Guild of Radiestets and Bioenergotherapists, who live by telling people the existence of water veins and that the radiation of these hypothetical veins will remove a square cardboard placed under the carpet (PLN 50 / item) is to be "independent"! After all, they live by scaring people! Note that in this material there is no reference to the results of specific studies, but are all "round" statements like "there has been a 6-fold increase in the incidence of gastritis". Who watched where and where? Probably with a wand :)
    By the way, they do not write whether the radiation of water veins is more or less harmful than the radiation of medium voltage lines.
  • #17 5064200
    Madrik
    Help: 627
    Rate: 1191
    Many more people live by persuading people to new demons than dowsers.
    The latest research on the greenhouse effect has shown that:
    A: - All previous research on the relationship of CO2 with the greenhouse effect is worth nothing, because it was based on studies of air bubbles in Arctic ice. It turned out that ice is by no means a prison for gas and the results are skewed by a minimum of 40% to a maximum of 70% as compared to the actual state at the time the bubble was trapped.
    B: - new measurements have shown that the amount of CO2 in the atmosphere increases AFTER the greenhouse effect.
    Ecologists - if any of you add ...... to Hammer, you can now tear your legs off ...
    Bio fuel - rapeseed plantation needed to produce 1 ton of fuel produces a similar amount of methane as the amount of CO2 from the combustion of 1 ton of regular fuel by a car. Only that methane is 30 times more dangerous to the environment than CO2 and actually contributes to the greenhouse effect. Let us live in harmony with nature and keep extracting ecological oil. The oceans are almost untouched, they will last for the next thousand years. Maybe someone will have time to invent an effective wind farm.
    CO2 - Annual world CO2 emissions caused by human activity account for the entire ... 7% of total global CO2 emissions to the atmosphere. The barge, a paltry 93%, are oceans, volcanoes, and living organisms.
    Keep reducing the amount of emissions. This goddamn Amazon forest is destroying your efforts in 1 day and stupid Etna is giving you credit for 5 years ahead. So what? To protect the environment, cut down the forest and plug Mount Etna?
    Good luck.
    But people's fear makes so much money ...
    So now someone tell me how much Tesla has the earth's natural magnetic field, which is one big magnet. And how much is 200 nano tesla? Because the numbers look impressive until someone presents comparative data and it turns out that this beam is actually a poor match. :D
    And the best.
    Ice ages occur cyclically. The next one is ... well over a thousand years behind. He can drop by at any time.
    And I doubt that mammoths had cars that burned more than Kamaz when they started, and they ran over glaciers anyway.
  • #18 5067190
    Enpro
    Help: 39
    Rate: 97
    marcint2525 wrote:
    Do not worry. There is already a trend towards the cable construction of MV networks. Partly the MV cable runs in the ground ... partly along with the LV cables along the poles ... It is made on a special cable, probably of Czech production. So far, this method is used in newly built or modernized power grids. But in a few years ... all cables will be buried. This does not apply to MV , WN and LV transmission lines.
    Somewhere you read these fairy tales, MV cables were already a German digging into the ground before the war, although they were 3KV but they have been buried in the ground for over a dozen years as needed, and not a tendency. Most of the MV lines from the wired ones are mostly in the city and a few sections outside the city. As for the low, your few years, e.g. 5, multiply it once by 10 and they will not yet, show me a European country where all n / n lines are wired, let alone poor Poland
  • #19 5067928
  • #20 5068517
    HeSz
    Electrician specialist
    Help: 97
    Rate: 198
    I will repeat what I wrote in the forum on the 110 kV network.
    Why is everyone talking about the harmfulness of radiation when a positive effect has also been observed (or perhaps above all)?
    Greetings.
  • #21 5068718
    prez8s
    Help: 69
    Rate: 334
    Why is everyone talking about the harmfulness of radiation, if a positive effect was also observed (or perhaps above all)?
    Greetings.
    What??? For what???
  • #24 5069952
    HeSz
    Help: 97
    Rate: 198
    I'm not kidding! Everyone who does not like the MV and WN lines is trying to prove that they are harmful. And they are to the same extent as many other things, such as exhaust fumes, noise, fields from TV transmitters, etc. Only that nobody fights with cars, TV but power lines disturb everyone. Research results vary depending on the requirements of whoever commissioned them. And since they are usually commissioned by those who are disturbed by the lines, the results also prove the "deadly threat from power lines .. and of course cyclists"
    Greetings.
  • #25 6609833
    blackknight
    For me, the law firm won 200,000. compensation for poles on the plot - I can recommend it by e-mail: miguel7(_at_)o2.pl
  • #26 6610295
  • #27 6610484
    keszan
    Help: 32
    Rate: 76
    1. I wonder why everyone is assuming that the pole is owned by the power industry?
    2 I wonder if the pole works in an active line?
    3. I wonder if it is a temporary or a target solution? I wonder if it is not a photomontage although I find it unlikely?
    4. I wonder about the reason for the investment made in this way?
    5. I wonder where (in which country) the construction site is located, despite the fact that I can assume from the warning sign that it is in Poland?
    6. I wonder why do we pass sentences with so little knowledge?
  • #28 6610695
  • #29 6610753
    keszan
    Help: 32
    Rate: 76
    Col. mansory.
    I worked at ZE, I know what it is like. !!!
  • #30 6611968
    stomat
    Help: 257
    Rate: 1982
    We came back to the thread from over a year ago because some law firm is looking for deer to stretch?
    I wonder if the founder of the plot bought this plot. As if the law firm won 200,000 zlotys for him, he would have a free plot and still earnings :)
The discussion revolves around the implications of purchasing a plot of land that has a 20 kV medium voltage line running through it. Forum members express concerns about the minimum distance required from the line to obtain a building permit, the potential health risks associated with electromagnetic fields, and the complexities involved in removing the pole if necessary. Some participants suggest that if there is no easement and the pole has been in place for less than 30 years, it may be possible to have it removed. Others caution against buying such plots due to safety risks and the potential for costly legal battles with the power company. The conversation also touches on the future of medium voltage lines, with some suggesting a trend towards underground cabling. Overall, the consensus leans towards caution when considering such a purchase.
TL;DR: Polish regulations set a 3 m side clearance for 20 kV overhead lines to dwellings, “minimum 3 m horizontal” [MI, 2002]. Keep this distance to secure a building permit and avoid costly (~70 000 PLN) pole relocation [Energa, 2021].
Why it matters: Buyers can prevent legal dead-ends and safety risks before signing the deed.
• Clearance for 1–45 kV lines: 3 m horizontal; 4 m vertical above roofs [MI, 2002]. • EMF limit in Polish living areas: 10 kV/m electric, 60 µT magnetic [ME, 2019]. • Average relocation cost per MV span: 70 000–150 000 PLN [Energa, 2021]. • Typical MV magnetic field at 10 m: ≤1.5 µT—<3 % of limit [WHO, 2007]. • Step-voltage during conductor break can reach 4 kV within 10 m [CIGRE, 2018].
What is the legal minimum distance for a 20 kV overhead line from a house in Poland?
Building law requires at least 3 m horizontal clearance and 4 m vertical to roofs for conductors up to 45 kV [MI, 2002]. This distance satisfies planning offices and lets insurers cover the structure.
Does the same clearance apply to garages, sheds or metal fences?
Non-habitable outbuildings still need 3 m side clearance, but vertical distance may drop to 2.5 m when roofs are conductive and earthed [MI, 2002]. Fences only need to stay outside the swing of the conductor plus 1 m safety margin.
How strong is the magnetic field under a 20 kV line?
Field strength directly beneath a typical rural 20 kV feeder seldom exceeds 5 µT; at 10 m it falls to ≈1.5 µT [WHO, 2007]. The Polish residential limit is 60 µT [ME, 2019].
Are electromagnetic fields from 50 Hz power lines proven harmful?
Major reviews find “no conclusive evidence” of health effects below guideline levels [WHO, 2007]. Forum posters echoed the uncertainty [Elektroda, Madrik, post #5055837]
Who pays for relocating a medium-voltage pole?
Without recorded easement, parties negotiate. In practice, landowners cover design, materials and labour—70 000–150 000 PLN per span [Energa, 2021]. Some owners have won compensation in court [Elektroda, blackknight, post #6609833]
How long does relocation usually take?
Design plus permits take 4–8 months; construction adds 2–6 weeks, longer in winter or wetlands [Energa, 2021].
Is burying the medium-voltage cable an option?
Possible, but trenching, joints and terminations raise costs to 250 000 PLN per 100 m [PGNiG, 2020]. Thread users note cables already replace some spans in cities [Elektroda, Anonymous, post #5067928]
What happens if the conductor snaps over my plot?
A live wire on the ground can create step voltages up to 4 kV within 10 m radius [CIGRE, 2018]. One poster advised keeping feet together when retreating [Elektroda, Melonson, post #5055884]
Three-step check before buying a plot near MV lines
  1. Measure horizontal distance with a laser rangefinder.
  2. Verify easement status in the land register.
  3. Request the utility’s development plan in writing. Complete these steps before signing the notarial deed.
Can I receive compensation for existing poles?
Courts increasingly grant 50–150 PLN per m² of occupied land plus a one-time 5 000–30 000 PLN for easement rights [MinJust, 2022]. Forum user reported 200 000 PLN award [Elektroda, blackknight, post #6609833]
