[Solved] Windows 10 - does not work START - When you click on START, only the menu backgr
ChBeata 9984 3
  • #1 16797863
    ChBeata
    Good morning, please forgive me for the infantile question, and I have a problem with the START menu in Windows 10.
    Explanations from a similar topic did not help :(
    After clicking the left button, the background opens, but the list and program icons are not shown and the background disappears after a while. Sometimes only the program list will appear without the tiles pinned next to it, but it closes very quickly and nothing can be clicked.
    I am asking for help and explaining how a cow is on a ditch ;)
    Thank you very much in advance :)
    Added after 5 [minutes]:
    I downloaded the troubleshooting tool from the Net from the net and showed me that the "Microsoft.Windows.ShellExperienceHost" and "Microsoft.Windows.Cortana" applications should be correctly installed, but how to do it: /
  • #3 16873970
    rtv.sos.pl
    Help: 14
    Rate: 17
    It should be examined whether there is a group of "ALL APPLICATION PACKAGES" in HKEY_CLASSES_ROOT in permissions. The group should have READ privileges. If it is not there, you should create such a group and check the permissions checkbox. After restarting it should work. The problem concerns the installation of some versions of the application - especially older versions. After installation, such miracles appear :D
  • #4 17036834
    ChBeata
    Unfortunately, the problem was solved only after the next system update :( no other way has helped :(
