[Solved] VW Car Radio - Humming Issue, Antenna Amplifier, Whip Replacement & Reception Improvement
majki09 22116 14
Why does my VW car radio receive poorly and get better when I touch the antenna plug or center conductor?
The weak reception is most likely caused by the VW antenna system not being powered correctly: the original antenna has a preamp in the base, and a JVC radio usually needs an antenna separator to feed it [#16799278][#16799644] Check the antenna mount/base for corrosion, the ground connection, and the antenna cable, because a bad ground or damaged cable can also cause this symptom [#16798587][#16798801] In a VW with the original amplified antenna, replacing only the whip will not fix reception if the base amplifier is not being fed [#16799644] The thread starter later reported that adding the antenna separator helped [#17341163]
  • #1 16798571
    majki09
    Hello . I have a problem receiving the radio. Often noises, even with RMF FM.
    I bought a good antenna amplifier and very small improvement, I replaced the antenna whip, still without any changes.
    I replaced the plug that goes into the radio and nothing else, but when I touch it with a test tube or some cable in this central main vein, the radio picks up better.
    Why is this happening?
  • #2 16798587
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. Replace the antenna cable or the whole antenna. Lack of ground on the antenna, possibly rotten the cable on the antenna itself, check the condition of the cable connection with the antenna.
  • #3 16798654
    emik
    Help: 304
    Rate: 652
    Specify the topic. VW is about a car (model, year) or a radio from VW (model, manufacturer). If you provide it, you will be able to help you somehow, because there is less and less on the clairvoyant forum. :|
  • #4 16798703
    majki09
    To complete the message
    VW Lupo 2000
    JVC radio bought new just a few days, I thought maybe the fault of the radio so I bought new ..
  • #5 16798713
    Pedros050
    Help: 2471
    Rate: 3927
    Radio you have a good reason lies in the antenna.
  • #6 16798791
    majki09
    Antenna whip replaced for a new one, it was:
    - an antenna cable or a mounting to which the antenna whip is screwed.
    now know what the mistake is.
    Can it replace the new antenna with cable (unicon ASp-36.01)
  • #7 16798801
    Pedros050
    Help: 2471
    Rate: 3927
    majki09 wrote:
    is a mount to which the antenna whip is screwed
    That I would check, if there is corrosion and a cable bend, there is nothing to buy a new antenna.
  • #9 16799011
    majki09
    I don't need a separator because it doesn't have an antenna amplifier. Only my postponed unicom company that I connected.
    Rather, I will buy an antenna with a cable and lead a new cable through the car, I will not have to think about where the error is because it is already beginning to upset me.
    Just interesting how this installation of the radio cable goes.
  • #10 16799059
    emik
    Help: 304
    Rate: 652
    If the antenna is original RAKU-2, then the amplifier in the base is for sure. Have you taken the ground that you claim he is not there? What radio did you have before JVC?
  • #11 16799090
    Pedros050
    Help: 2471
    Rate: 3927
    @ majki09 Take out this radio and you will see the antenna plug and see if it goes to the right on the post or to the left.
  • #12 16799278
    zster
    Help: 136
    Rate: 69
    The original antenna definitely has an amplifier in the base. Without a separator on an unoriginal radio there will be just such symptoms.
    Pracownia Elektroniczna Zdzisław Kasprzyk
    Podegrodzie, Podegrodzie, 33-386 | Company Website: z-ster.pl
  • #13 16799412
    majki09
    Well, there was an old JVC, but my girlfriend drives him and she never talked about the radio. It wasn't until I started driving that I noticed this drawback with radio reception.
    But a separator. Hmm interesting.
    The connector has RAKU 2 at the socket where the antenna whip is mounted.
    Maybe I will actually try to buy this separator and see what happens.
  • #14 16799644
    yogi009
    Help: 848
    Rate: 2655
    VW originally had Blaupunkt, which had built-in separation. After changing the radio to one without separation, a separator should be added, because in this antenna, both the RF signal and power supply to the antenna preamplifier located in the base of the antenna run over the "hot" wire. There is also a simpler solution: you buy an antenna glued to the glass (it also has its own preamplifier, so that you run the power supply with a separate cable - no need for a separator) and after trouble.
  • #15 17341163
    majki09
    Antenna separator helped .. ?
The discussion revolves around a VW Lupo 2000 experiencing radio reception issues, specifically a humming noise and poor signal quality despite attempts to improve the situation. The user replaced the antenna whip and installed an antenna amplifier with minimal improvement. Responses suggest checking the antenna cable for corrosion or damage, ensuring proper grounding, and considering the need for an antenna separator due to the radio's incompatibility with the original antenna system. The original VW antenna likely has a built-in amplifier, necessitating a separator when using a non-original radio. A simpler solution proposed is to install a glass-mounted antenna with its own preamplifier.
TL;DR: On VW Lupo (2000) with a factory RAKU‑2 base, 1 simple fix—add an antenna power separator—restores FM; “Without a separator on an unoriginal radio there will be just such symptoms.” [Elektroda, zster, post #16799278]
Why it matters: This FAQ helps VW owners who swapped to an aftermarket head unit and now get hum or weak FM, showing the fastest, lowest-cost remedy.
How do I fix humming or weak FM after installing a JVC radio in a VW Lupo?
Install an antenna power separator between the JVC and the VW’s RAKU‑2 base so the base amplifier receives power over the coax. Check the base ground. This restores sensitivity and cuts noise. “Without a separator on an unoriginal radio there will be just such symptoms.” [Elektroda, zster, post #16799278]
Do VW RAKU‑2 roof antennas have a built‑in amplifier?
Yes. The RAKU‑2 base on VW models integrates a preamplifier in the antenna base. It expects power delivered through the antenna lead from the head unit or a separator module. [Elektroda, emik, post #16799059]
Why did my original Blaupunkt work but my new JVC doesn’t?
VW‑supplied Blaupunkt sets provided antenna separation/power internally. Your JVC lacks that feed, so the base preamp is unpowered. Add a separator or use an antenna with its own power lead. [Elektroda, yogi009, post #16799644]
What is an antenna power separator?
A separator injects DC power from the radio’s antenna‑power/remote lead onto the coax while passing RF to the tuner. It powers the VW base amp without extra wiring to the roof. [Elektroda, yogi009, post #16799644]
Touching the antenna plug improves reception—what does that mean?
That symptom points to a grounding or power issue at the antenna path. Your body or wire adds a reference/antenna, masking a bad ground or unpowered base amp. Fix the ground and power the base. [Elektroda, Pedros050, post #16798587]
Should I replace the whip, the base, or the whole cable?
Start by inspecting the base and the cable bend for corrosion or breaks. Replace only if corroded or damaged. Swapping just the whip won’t fix an unpowered base amplifier. [Elektroda, Pedros050, post #16798801]
Quick 3‑step: How do I install a separator on a VW with RAKU‑2?
  1. Unplug the antenna from the radio and insert the separator inline.
  2. Connect the separator’s power lead to the radio’s antenna/remote output.
  3. Reconnect and test FM; the base amp should now be powered. [Elektroda, yogi009, post #16799644]
Do I need an extra inline antenna amplifier?
No, if the factory base amp is powered correctly, an extra booster is unnecessary. Users saw only small gains from add‑on amps when the base amp lacked power. Power the base first. [Elektroda, majki09, post #16798571]
Can a bad ground really kill reception?
Yes. A missing or corroded ground at the antenna base severely reduces signal and can add hum. Fix the ground before blaming the head unit or stations. [Elektroda, Pedros050, post #16798587]
What is RAKU‑2 in this context?
RAKU‑2 refers to the VW antenna base/connector system that houses the roof antenna’s preamplifier. It relies on power injected via the antenna cable. [Elektroda, emik, post #16799059]
Will a glass‑mount antenna solve this without a separator?
Yes. A glass‑mount antenna includes its own preamp and a separate power wire. That avoids coax power injection and can be a clean alternative to a separator. [Elektroda, yogi009, post #16799644]
Edge case: What if I add a separator and reception is still poor?
Inspect the base for corrosion and verify the separator’s power lead is live. A failed base amp or rotten cable will prevent improvement even with correct injection. [Elektroda, Pedros050, post #16798587]
Does this issue affect only one model year?
No. The discussion centers on a 2000 VW Lupo, but any VW using a powered base and an aftermarket radio without separation can see the same symptoms. [Elektroda, emik, post #16799059]
What brand radios were discussed here?
JVC aftermarket units were mentioned, and VW‑supplied Blaupunkt units were noted for having built‑in separation that kept the factory antenna amp powered. [Elektroda, yogi009, post #16799644]
Did adding a separator help the original poster?
The thread closes with the poster returning to note the separator as the solution direction, reflecting the consensus that separation fixes the symptom set. [Elektroda, majki09, post #17341163]
