Audi A4 B5 1999: Rear Brake Piston Issues after Caliper Regeneration & Handbrake Disc Repair
misterbociek 10317 9
Why do the rear brake pistons on an Audi A4 B5 not retract after caliper regeneration, and why does the pedal behave strangely?
The rear pistons should retract only a little through the piston seal, so if they do not return after a rebuild, the likely causes are still trapped air in the system (including the ABS pump) or a problem with the caliper seals, piston cleanliness, or lubrication [#16855026] [#16855106] [#16855135] [#16855182] [#16855285] Bleed the brakes again, ideally on the running car, and keep forcing the fluid out rather than relying only on seeing bubbles [#16855156] [#16855135] Check that the rebuilt calipers were cleaned properly and that the piston seals/gums are fitted correctly and let the piston move back slightly [#16855182] [#16855285]
  • #1 16854961
    misterbociek
    Help: 40
    Rate: 120
    Hello!
    Audi a4 b5 1999, handbrake disc.
    I have such a problem that I have recently regenerated the rear calipers (seal and piston cover) and now they do not want to bounce back the pistons. In general, all the liquid spilled to zero after unscrewing the clamps. I have assembled everything, the terminals have been bled (there are no bubbles) twice with my brother on the engine off and they do not move backwards, the front ones are OK.
    As I normally get into the car, the brake pedal is hard, it is hard to drive it in, after turning the engine on, you can press the pedal halfway down without using force, while the car does not brake, only from this half there is resistance and the car brakes.
    What could it be ?
  • #2 16855026
    andrzej20001
    Help: 1578
    Rate: 6669
    Air in the system
  • #3 16855043
    misterbociek
    Help: 40
    Rate: 120
    Well, I flew all the wheels twice with my brother and zero bubbles: / Tomorrow maybe we will try to pain.
    Or could it be the fault of an air-pumped ABS pump?
    One person writes:
  • #4 16855106
    andrzej20001
    Help: 1578
    Rate: 6669
    The system is air in. The system also includes an abs pump
  • #5 16855126
    misterbociek
    Help: 40
    Rate: 120
    OK, I understand and I have one more question:
    How do the pistons retract after braking? There are no springs on the clamps. I thought that when we release the brake pedal, the fluid goes back and a vacuum is created, which draws the pistons back, but rather the vacuum will draw fresh fluid from the reservoir.
  • #6 16855135
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Most likely in this model, the piston seal retracts it because it brakes slightly when braking. This undo is minimal.
    Bleed by squeezing the fluid out.
  • #7 16855156
    Ireneo
    Help: 747
    Rate: 2472
    You did the regeneration of the clamps yourself. Well cleaned? Bleed on the fired car.
  • #8 16855181
    misterbociek
    Help: 40
    Rate: 120
    I regenerated the clamp myself, go unnecessarily, because someone was already there, because the piston is in perfect condition. Generally, earlier (blocked clamp) guilty guilt was because there was a terrible crap that I broke old blocks with a hammer.
  • #9 16855182
    przemek25l
    Help: 124
    Rate: 372
    The question is whether well done regeneration. Well cleaned pistons, piston grease used?
    Because often this is a problem.
  • #10 16855285
    andrzej20001
    Help: 1578
    Rate: 6669
    Look at the gums and you can see why they are going backwards
The discussion revolves around issues with the rear brake pistons of a 1999 Audi A4 B5 after the regeneration of the calipers and repair of the handbrake disc. The user reports that the pistons do not retract properly, resulting in a hard brake pedal and ineffective braking. Responses suggest that air in the brake system, including the ABS pump, may be the cause. Several users recommend ensuring proper bleeding of the system, particularly with the engine running, and checking the condition of the piston seals and cleanliness during regeneration. The mechanics of piston retraction are also discussed, highlighting that the brake fluid's return and vacuum effects play a role in this process.
