Opel vivaro 2.0 90KM 2001 - How to drain the fuel from the tank?
Kamkalekaka 14331 4
  • #1 16805367
    Kamkalekaka
    Rate: 33
    I have a problem, I need to drain the fuel from the tank from the bus, but I don't know how to do it. Others write to unfasten the hose from the filter and drain it, but it does not work. Urgent response please!
  • #2 16805419
  • #3 16805431
    Kamkalekaka
    Rate: 33
    Okay, thanks a lot for the info, I'm going to act
  • #4 17455663
    rafa0015
    Rate: 14
    Hello, I will go to the topic of whether this car has access from the cargo box to the fuel tank, or is there any cover to the place where the fuel hoses and the level sensor are connected. I do not see it at home because I have a body at the back, if it is to break the floor and if there is no channel waiting for me. Thank you for your advice and best regards
  • #5 17455678
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6433
    So, disconnect from the filter and put the hose down to the ground and either suck or inflate the tank. To do a circuit.
