VW passat b5 fl estate 1.9 - The indicator light from the manual is constantly f
miczka186 21183 7
  • #1 16561482
    miczka186
    I keep blinking from the manual light and every now and then it squeaks ... on the computer showed that everything is ok ... the fluid agrees with the brakes ... maybe someone knows what it could break ?????
  • #2 16561516
    piotrek22101
    Help: 695
    Rate: 1421
    To check the plugs, ABS sensors.
  • #3 16561520
    miczka186
    And where are they located ????
  • #4 16561522
    piotrek22101
    Help: 695
    Rate: 1421
    Under the car, by the wheels. It's best to connect the vaga, it will show if it's ok
  • #5 16561574
    miczka186
    Ok, I will try to do that thanks a lot
  • #6 16561821
    wiki14tm
    Rate: 34
    stop sensor? check if you have all your feet "lights" and other bulbs in the rear lamps
  • #7 16562375
    miczka186
    Would the manual light come on ??? As if I didn't have any back light ????
    Added after 30 [minutes]:
    The stop lights are all behind
    • VW passat b5 fl estate 1.9 - The indicator light from the manual is constantly f 14989088948171474344777.jpg (705.73 KB) You must be logged in to download this attachment.
  • #8 16562444
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    like an indicator light with an exclamation mark, it must be something related to brake fluid. If you have the correct fluid level, it doesn't mean the car can see it either. See if you accidentally dropped the cube from the sensor in the tank, or the cable has not corroded at the plug itself
The discussion revolves around a persistent indicator light issue in a VW Passat B5 FL estate 1.9, which is accompanied by occasional squeaking sounds. The user reports that a diagnostic check indicated no problems, and the brake fluid level appears normal. Responses suggest checking the ABS sensors and plugs located under the car near the wheels. Additionally, it is advised to inspect the stop sensor and ensure all rear lamp bulbs are functioning, as the indicator light may relate to brake fluid detection issues. The possibility of a faulty sensor or corroded connections is also mentioned.
