Vw Golf 4 1.9tdi: Persistent Red Exclamation Mark at 15kmh, No Leaks or Brick Sensors
Tomol94 5262 4
  • #1 16893553
    Tomol94
    Hello. A red exclamation mark in the center of the clock has been lighting up for some time. It ignites and bursts 3 times and then only blinks all the time. This happens when I reach a pressure of 15kmh and flashes all the time. When you turn off the car, it will start (not flashing) until it reaches 15kmh each time. I have liquid, I don't have leaks, I don't have brick sensors. I do not know what it can be. Do you have any ideas?
  • #2 16893557
    pawel16150
    Level 30  
    Help: 204
    Rate: 640
    Show picture of this control
    Added after 8 [minutes]:
    Is the ABS indicator light off?
  • #3 16893607
    Tomol94
    Indicator with an exclamation mark in brackets. That's how abs burns all the time. I have a broken abs driver on vag.
  • #4 16895329
    Blicek
    Help: 82
    Rate: 217
    What error exactly?
  • #5 16895836
    Tomol94
    Blicek wrote:
    What error exactly?
    01044
