VW T5 1.9 TDI BRS 2007: ABS ESP Indicators Glowing, VAG Error 668, Rear Right Wheel G44 Sensor
darko b 8178 2
  • #1 16278848
    darko b
    Rate: 103
    Hello, I have a problem with the ABS ESP indicators glowing. On VAG error 668 and the sensor of the rear right wheel G44. I replaced the sensor, the fuses are checked. On the sensor cube, the meter was also showing something. The error shows something with tension. Are there any weak points in this car where the beam can wear? What else could I check?
  • #2 16282330
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    Check the abs pump, and carefully its plug, and check if you have power. As I remember correctly, two pluses and two masses.
  • #3 16283025
    darko b
    Rate: 103
    The first time I was looking badly. There is no voltage on the plug near the sensor. The ring in the hub has also been excluded by connecting the plug from the second wheel for a test. There is a cube under the driver's seat with almost 12V after turning the key, i.e. there is a gap somewhere between the seat and wheel.
