Zebra GK420t - Constantly Releases Blank Labels After Roll Change, Unresponsive Feed Button
detonator 16770 4
  • #1 16805926
    detonator
    Rate: 18
    today, after changing the roll in the printer, miracles began. Well, it does not print anything, and constantly unwinds labels from the roll. What could happen to her? The new roll is the same as always, the computer has nothing in the print queue, the unwinding can only be stopped by turning it off, the feed button does not help ...
    Do you have any ideas?
    Bitels85
    Help: 72
    Rate: 166
    It needs to be calibrated with the controller or with zebra designer. In addition, it is worth checking the settings, i.e. whether the sensor break detection is well set.
  • #3 16828299
    detonator
    Rate: 18
    At the moment, we have managed to stop the waste of labels by manually setting the size of the labels. Unfortunately, no calibration was effective, neither the one released from the controller nor the one by holding the feed button. Maybe one of the sensors has gone out or is dirty ...
    camylca
    Indeed, I suggest checking if the sensor is dirty, if it is dirty, clean it with a cotton cloth or use compressed air cleaning.
    Moderated By rys57:
    3.1.10. Do not advertise websites or services in any form.
    The advertising part has been removed.
  • #5 16832684
