[Solved] Vectra b 2.2 dti - VP-44 solenoid valve of the injection angle adjuster is damag
darkomanta 18825 12
Why does the VP44 injection angle adjuster solenoid keep failing in my Opel Vectra B 2.2 DTI, and should I replace the pump controller or regenerate the pump?
In this thread, the problem was ultimately solved by replacing the injection angle adjuster valve with a new one, not by regenerating the pump or changing the controller [#17586191][#17586223] One technical explanation offered was that a sticking actuator plunger can make the controller drive the valve with very high fill pulses, which may overheat or damage the coil [#17098245] Another reply noted that if the speed sensor is OK, P1335 can point to a damaged pump controller, and that PSG5 systems do not need immobilizer coding when swapping controllers [#17582563] In the end, however, the observed fix was simply a fresh valve: after replacement, the set and actual injection angle matched again and the car ran properly for months [#17586191]
  • #1 17058310
    darkomanta
    Help: 13
    Rate: 17
    I am asking for help in the correct diagnosis of the Vp-44 pump fault in my VB y22dtr. As in the topic, the solenoid valve of the injection angle adjuster (0281002173) is persistently damaged, the lower one on thinner cables. It is damaged in such a way that there is an interturn short circuit in its coil, its resistance becomes 2 ohms instead of 8-10 (This is how many valves I installed were in working order). In this state, the engine works, but after adding gas, it immediately enters the emergency mode, it is very gray, the check engine light comes on. In op-coma measuring blocks, the actual start of injection is 18.1 ° instead of the set 4.7 °. This error occurs: P1335 - "Injection Pump: No Engine Speed Input Signal From Control Module". Importantly, there is no error P0725 suggesting damage to the shaft sensor, but I replaced it anyway. It did nothing. There are also no typical errors of "falling" pump, ie: P1220, P1631, P1651 etc. I checked the wiring diagram from the engine controller to the pump controller, everything ok. After inserting a new solenoid valve, observed in blocks, the start of the injection is set and real, it is perfect cover and amount to about 4.7 °. The car drives perfectly for a period of about a week and then the solenoid valve of the adjuster is damaged again. Interestingly, the defect appears during parking or rocking in a traffic jam, and not during dynamic driving.
    After consulting with experts, two completely different theories emerge. Namely:
    The rubbing of the adjuster piston causes that the pump controller, striving to maintain the desired injection start, "pumps" such PWM pulses onto the solenoid valve, that its coil is damaged.
    The opposite theory is that even if the setting piston rubs, it still does not affect the operation of the solenoid valve and its repeated damage is caused by an unusual and irreversible damage to the pump controller (probably the 7-pin element controlling the solenoid valve).
    I would like to add that when the solenoid is still ok, there are no strange symptoms while driving, even very dynamic, no interruptions, etc. I have been adding 2t oil to the fuel for a long time. The controller itself is in a revised version, i.e. the famous transistor controlling the dose adjuster goes from the board 3 wires, including 2 parallel to the source of the transistor and one to the gate. In the original, there is one each. The driver inside is impeccable. It looks like the pump was made by our western neighbors in 2003 and got a new "revised" driver. In addition, a newer soft is installed, thanks to which the glow plugs on a cold engine always heat up regardless of the ambient temperature.
    What do you advise, replace the driver for 6 sts or regenerate the pump for an amount exceeding the value of the car? Have any of your colleagues encountered a similar driver fault? Because if it actually has such a "strange" fault, the regeneration of the pump mechanics may be pointless and will not improve the car.
    Wojtek(KeFir)
    Help: 678
    Rate: 562
    Can you measure the valve current? How is it damaged? Your coil is burning?
    helmud7543
    Help: 1216
    Rate: 1564
    I would be weak with mechanical damage - if it does not burn the transistor, it is another weak link.
    Pawel wawa
    Help: 1262
    Rate: 4432
    Measure buddy charging voltage.
  • #5 17058784
    darkomanta
    Help: 13
    Rate: 17
    Damaged valves have about 2 Ohm one and about 3 Ohm the other. So an intergurnal short circuit. I broke one down during disassembly because the torx screws were damaged and I couldn't unscrew. Working valves have about 10 Ohm, the original 0281002173 I also got and installed, it had about 8 Ohm. Like the others, it "fell" after a week.
    Ohm's law shows that the current is just over 1 A. But in a pulse. The only question is what do these impulses look like? I wonder if the fault of the controller may be based on its behavior that at certain times it gives a DC voltage instead of pulses and this damages the solenoid valve coil. These are of course only theoretical considerations, not even guesses, but it gives me another idea. I have already bought another solenoid valve. I will install it in such a way as to approach the oscilloscope probe and view the waveforms on the patient.
    I will measure the charging voltage when I put in a functional solenoid valve. There was never a problem with the voltage in the installation, the alternator is from Vectra with a current efficiency of 160A.
  • #6 17076299
    darkomanta
    Help: 13
    Rate: 17
    Pawel wawa voltage measured on the battery 14.4V. New solenoid valve fitted. So far, despite the bitter frost, the car burns and drives flawlessly. The weather is not conducive to making such measurements, but when it gets a little warmer, I watch the waveforms given by the controller for the solenoid valve on the oscilloscope, even while driving. I will solder the rg58 cable to the solenoid valve and pull it inside. I have repaired some of these drivers and I think I will fail. Just confirm my belief that single-plug psg5 in Opel dti does not require immo coding? In other words, can I substitute a second, of course, same controller and start the car without programming the immobilizer?
    Wojtek(KeFir)
    Help: 678
    Rate: 562
    Take the damaged one and pick it out, try to find the short circuit in the coils. From its appearance, it will be possible to more or less assess what caused it. Is it all overheated and failed or is there a point of burnout that would indicate an insulation fault.
    Wlodek22
    Help: 78
    Rate: 526
    There is also a possibility that the low pressure pump itself gives too low pressure and the controller is trying to get the set angle with the length of the solenoid pulses. Check the quantity, the flow of oil on the return, although I do not know how much on idle she should be pumping. Basically I bet on pump mechanics, plunger or low pressure pump.
  • PSG5 controller swap may start without immo coding
    #9 17098183
    darkomanta
    Help: 13
    Rate: 17
    Włodek, there is no low pressure pump in VB dti. The fuel is sucked by the injection pump, there is no booster pump in the tank. However, the system is tight, it does not contain air. On the return, when the engine is running, the fuel flows out very intensively. I know it's a relative term, but here it seems that everything is fine. So far, another solenoid valve is installed and the engine works as it should. Hint if in the case of psg5 (Vp-44 for one plug and the engine controller on the shaft) in the Opel dti I can substitute a second, same controller and start the engine without immo programming?
    Seized actuator plunger likely overdrives valve
    #10 17098245
    Wlodek22
    Help: 78
    Rate: 526
    See the schematic of this pump. The low pressure pump is the one on the left. Since it is fine after replacing the valve for some time, it is probably not a pump issue, although it may be a source of filings. It is more likely that the actuator plunger seizes and the controller bombards the valve with very high filling pulses whenever it is blocked.
  • #11 17582563
    naprawa-pomp.com
    Rate: 143
    There is no immobilizer in cases with the PSG5 controller. The injection angle valve is actually around 10 Ohm and draws ampere with a penny. Although the longer it works, the more it heats up, its resistance increases and the current decreases. After some time, a few minutes, it does not consume even one ampere, but it is very hot. Just turn the ignition on and leave it for a long time and the valve may boil. Although this is not a rule, for example: in Fords, the valve is also powered after the voltage is applied, and in others not depending on the pump number. And the most important. You wrote about the error P1335. If the rotation sensor is functional, the pump controller with this error is irreparably damaged. It is beyond repair. And it may damage this valve from the injection angle adjustment.
    PUH OMEGA
    brzozowa 57, Ożarów, 27-530 | Tel.: +48XXXXXXXXX (Show) | Company Website: puhomega.pl
  • #12 17586191
    darkomanta
    Help: 13
    Rate: 17
    Old times. The car runs smoothly for six months. On the third solenoid valve, the pump works flawlessly until today. Just used valves that I installed were probably tired of life and quickly damaged. It is best to buy a new one, they are commercially available. The pump did not require renovation and the controller is operational. Error p1335 resulted from the inability to adjust the injection angle by the controller and it appeared after the failure of the solenoid valve of the injection angle adjuster. After replacing it with a functional error, it was possible to delete the set and actual angles. As I mentioned before, the driver in the improved version with three legs for the structure - transistor keying with the adjuster. Therefore, it works without failures for over a dozen years and the second weak point of the pump has emerged, if you can say so after so many years. Probably also adding 2t oil to ON significantly contributed to many years of failure-free operation of Vp-44.
    Accurate diagnosis is sometimes difficult, but it allows you to avoid unnecessary costs, mass of work or even scrapping a still quite good car. Thank you for the advice and best regards.
  • #13 17586223
    darkomanta
    Help: 13
    Rate: 17
    Added after 13 [minutes]:
    I was considering pump regeneration or driver replacement. However, replacing the solenoid valve of the injection angle adjuster with a new one solved the problem.
The discussion revolves around diagnosing a fault in the VP-44 injection pump of a Vectra B 2.2 DTI, specifically concerning the solenoid valve of the injection angle adjuster (0281002173). The user reports persistent damage to the solenoid valve, characterized by an interturn short circuit in its coil, leading to engine performance issues and error code P1335. Various responses suggest measuring the valve current, checking the charging voltage, and examining the controller's behavior for potential faults. After replacing the solenoid valve, the engine operates correctly, and the user inquires about the possibility of substituting the controller without immobilizer programming. The discussion concludes with insights on the longevity of the pump and the importance of using new components to avoid repeated failures.
TL;DR: A new 0281002173 timing solenoid fixed recurrent P1335; used ones failed within a week; "replacing the solenoid valve of the injection angle adjuster with a new one solved the problem." [Elektroda, darkomanta, post #17586191]
Why it matters: This FAQ helps Opel Vectra B 2.2 DTI owners diagnose and fix repeat VP44 timing-solenoid failures without unnecessary pump overhauls.
What are the telltale symptoms of a failing VP44 timing solenoid on Vectra B 2.2 DTI?
Expect limp mode after throttle input, heavy gray smoke, and a check engine light. In OP-COM, Actual Start of Injection jumps to ~18.1° while Set stays near ~4.7°. The ECU logs P1335: "Injection Pump: No Engine Speed Input Signal From Control Module." These findings point toward the timing solenoid circuit. [Elektroda, darkomanta, post #17058310]
What resistance should the 0281002173 timing solenoid read, and what indicates a short?
Measure the coil across its pins with the engine off. Healthy valves measure roughly 8–10 Ω. Damaged valves show about 2–3 Ω, which signals an interturn short in the winding. Replace any valve that measures far below spec to prevent repeat faults and controller stress. [Elektroda, darkomanta, post #17058784]
Should I measure the valve current, and what is normal?
Yes. Expect about 1 A initially. As the solenoid heats, its resistance rises and the current falls below 1 A within a few minutes. The body will feel very hot during extended energization, which is normal behavior for this circuit under key-on conditions. "Ampere with a penny" describes the draw. [Elektroda, naprawa-pomp.com, post #17582563]
Can leaving the ignition on overheat the timing solenoid?
It can on some pump variants. With key-on only, certain VP44 versions keep the angle solenoid powered; "the valve may boil" if left long enough. Others do not, depending on pump number and application. Avoid extended key-on tests without running the engine to limit thermal stress. [Elektroda, naprawa-pomp.com, post #17582563]
What does code P1335 mean here, and how was it resolved in this case?
In this case, P1335 appeared when the ECU could not adjust injection timing due to a failed timing solenoid. Replacing the solenoid restored alignment between set and actual angles, and the code cleared. No pump overhaul or controller replacement was required after the valve swap. [Elektroda, darkomanta, post #17586191]
Do PSG5 VP44 controllers on Opel DTI require immobilizer coding?
No. "There is no immobilizer in cases with the PSG5 controller." You can substitute a same-type PSG5 controller on these setups and start the engine without immobilizer programming steps. Match part numbers and connectors to avoid compatibility issues during testing. [Elektroda, naprawa-pomp.com, post #17582563]
Could a faulty PSG5 controller damage the 0281002173 solenoid?
Yes, it can. If the rotation sensor is OK yet P1335 persists, the pump controller is considered irreparable and "may damage this valve." In that scenario, replacing the solenoid alone will not last; the driver must be addressed. Verify sensor inputs before condemning the ECU. [Elektroda, naprawa-pomp.com, post #17582563]
Why did used timing solenoids fail quickly, and what finally fixed it?
Used solenoids were end-of-life and failed again within a week. Installing a new 0281002173 eliminated the recurring P1335, restored correct timing control, and kept the car running flawlessly for six months and beyond. New parts outlast tired salvage units in this application. [Elektroda, darkomanta, post #17586191]
Does the Vectra B 2.2 DTI have a lift pump, or only VP44 suction?
There is no in-tank booster pump on this setup. The VP44 itself contains an internal low-pressure stage, visible on the left in VP44 schematics. Fuel is drawn by the injection pump, so vacuum leaks or internal wear can affect supply. [Elektroda, Wlodek22, post #17098245]
Could mechanical sticking of the timing piston cause repeat solenoid stress?
Yes. A sticking actuator plunger can force the controller to drive high-duty pulses to chase the target timing. That increases thermal and electrical stress on the timing solenoid and can accelerate failure when the mechanism binds. Inspect the adjuster if symptoms persist. [Elektroda, Wlodek22, post #17098245]
Is charging voltage a factor here, and what was reported?
Charging voltage was measured at 14.4 V during troubleshooting. No abnormal overvoltage was found, and it was not the fault cause in this case. Still, verify your charging system when diagnosing repeated electrical component failures. [Elektroda, darkomanta, post #17076299]
How can I scope the timing-solenoid PWM safely during a road test?
Three-step How-To:
  1. Solder an RG58 coax lead to the solenoid’s wiring so a scope can probe the signal.
  2. Route the cable into the cabin, securing it away from heat and moving parts.
  3. Use an automotive-rated oscilloscope to capture PWM at idle and while driving. [Elektroda, darkomanta, post #17076299]
Which OP-COM blocks should I watch to confirm timing control?
Watch Set Start of Injection and Actual Start of Injection. On a healthy setup, they overlap closely at idle near ~4.7°. During failure, Actual spikes far ahead, such as ~18.1°, and limp mode triggers with P1335. [Elektroda, darkomanta, post #17058310]
Will adding 2T oil to diesel help VP44 longevity?
One owner reports long, failure-free VP44 operation while dosing 2T oil in the fuel. This is shared as field experience rather than a universal prescription, but it coincided with stable running after the new solenoid was installed. [Elektroda, darkomanta, post #17586191]
