Golf 4 1.4: Single Dull Knock in Left Wheel Area During Start and Brake - Fault Search
lanczes 6963 5
  • #1 16810108
    lanczes
    Rate: 14
    I am asking for help in finding the fault.
    When starting off and roughening up, listen to a single dull knock, felt more or less in the area of the left wheel. I go from mechanic to mechanic and everyone spreads their hands. According to specialists, the suspension is fine. Pillows as well. One of the mechanics replaced the left inner joint, the left spring was apparently broken, the caliper yoke. Please suggest what might be wrong.
    best regards
  • #2 16810118
    kkknc
    Help: 1915
    Rate: 6709
    You can't do it over the internet. You have to check physically. Yoke, clamp, guides, fastening company etc.
  • #3 16810167
    lanczes
    Rate: 14
    It was supposed to be checked. It looks like something is sliding back and forth. When I move, there is a knock, a knock is broken. A dull sound as if metal is hitting metal or something against the floor.
  • #4 16810271
    kkknc
    Help: 1915
    Rate: 6709
    Cushions, articulation etc.
  • #5 16830346
    M-A-T-E-U-S-Z
    Rate: 57
    Check the wishbone bushings
  • Driveshaft joints likely cause the knock
    #6 16830398
    LENIWIEC_PL
    Help: 119
    Rate: 322
    And I would check if the shock absorbers are mounted with rubbers and if the bearings in them are operational (not badly made). Take a ride over the pits and tell if the situation is the same. It is also worth checking if the bearings in the wheels are not damaged, but I would bet on the driveshaft joints because their wear often manifests itself in similar situations as in your case. Check them also on the right side (because the sound is hard to find).
