[Solved] VW PASSAT B5 FL 1.9TDI - Internal joint symptoms - continuous external replaceme
k0sa 19875 7
  • #1 17630076
    k0sa
    Rate: 16
    What are the symptoms of a damaged wrist ext. in the b5 FL 1.9TDI strap?
    I exchanged it for an outdoor vacation because it was knocking. After the exchange I heard some "stresses", crackles, squeaks from the pedals. Rather, it was such a sound as if the pedals creaked from old age and required lubrication with some spray agent. I drove on. The squeaking stopped, but the right knock sound came slowly again with the wheels turned right and forward / backward. After some time I replaced this wrist again. After this exchange, there were crackles from the pedals / box side again, so I analyzed them more thoroughly. When I go straight and then turn right, I can hear this screech and creak. When I turn right all the time and drive forward, then I go back, nothing. I have to go straight a little, then turn right and only then can I hear this creak. Of course, with time it stops and the right joint is again to be replaced, because with a strong turn it shoots, and after undressing the balls are crushed. It makes no sense to change the right wrist in circles, I need to find out the reason. He finds two (I think so):
    1. Half-curve - but from where? there is no reason for it to be a curve, nothing happened, I didn't have any unexpected actions
    2. Right inner joint - it has never been replaced, but does it affect damage to the outer right joint?
    I'm in a pinch, I have no ideas .... anyone knows the symptoms of this strange behavior?
    The car itself, even at the dynamometer, spat out 138km and something ~ 330-340 newtons from what I remember, suspension done, the same symptoms on summer (alu rims) and winter wheels (nibs). Shields also made, bosh blocks themselves - almost all, nothing creaks, nothing throws the wheel: /
    LIBERTI Michał Kosowski
    Braci Wieniawskich 1/27, Lublin, 20-844 | Company Website: www.SEVENTI.pl
  • #2 17630410
    piachu1994
    Help: 559
    Rate: 1159
    The inner joint may get stuck and the shaft will not move when turning towards the box.
  • #3 17630871
    borguss
    Help: 12
    Rate: 10
    Hello, I would also put on the inner joint and for peace when the half-shelf is removed, throw it on such rollers on which you can check the runout. In practice, it doesn't have to happen for the half-axle to bend. These things just happen if there was something with a suspension, for example.
  • #4 17632246
    Staszek49
    Help: 228
    Rate: 1140
    For information only - I had a Passat meeting with a high curb and mechanics replaced the swingarm with a new one. I rode after this fact for about 6 months, i.e. until the wheels were changed into winter tires, and then the specialist stated that I had a lot of slack in the right wheel bearing, resulting from the unscrewing of the axle nut. He tightened the nut "pneumatically" and I was calm for a week.
    Unfortunately, the axle nut has loosened, so I tightened it tightly, adding a counter, i.e. a second nut. Despite this, the fault repeated, so after lifting the wheel and turning it, I noticed the curve of the drive shaft, which the mechanics did not notice before. All in all, I had to replace the wheel hub and axle shaft because of their fault, because the axle shaft caused the hub to "decalibrate" the bearing.
    It is also true that there were no suspicious signs while driving. fault.
    To sum up, check that you don't have a drive shaft curve.
  • #5 17632296
    k0sa
    Rate: 16
    Thank you all for the answers. I thought so too. I'll check it out after the weekend.
  • #6 17632313
    kkknc
    Help: 1915
    Rate: 6709
    The car can be ringed. And it doesn't keep the distance which can damage joints.
  • #7 17632407
    k0sa
    Rate: 16
    Is not :-) Before, everything was fine. Although reportedly 90% of the belts are currently on the market, this folding was never folded :-)
    It came about while doing the suspension this summer, and we managed to set the convergence. Since then, I have constantly replaced the right wrist.
  • Worn wishbones caused rattling and high-speed wobble
    #8 19124513
    k0sa
    Rate: 16
    Right lower front wishbone, apparently working, but it was very old (over 5-6 years) + left lower rear wishbone (banana, just as old and apparently ok), but after replacing both, there is no rattling, no wobbling over 150km/h, and it stands straighter on straight terrain. All great, the rest of the suspension is up to 3 years max and they are either lemforder or febi, also quiet for a long time. I forgot to close the topic :-) .
The discussion revolves around symptoms of a damaged inner joint in the VW Passat B5 FL 1.9TDI, particularly focusing on knocking sounds and creaking noises from the pedals during turns. Users suggest that the inner joint may become stuck, leading to issues when turning towards the gearbox. One participant shares an experience of replacing the swingarm and later discovering slack in the right wheel bearing due to a loose axle nut, which ultimately required replacing the wheel hub and axle shaft. The conversation emphasizes the importance of checking for drive shaft curvature and ensuring proper alignment to prevent joint damage.
