Golf 3 Engine 1.9 TDI 90KM 1Z: Rhythmic Knocking Near Gearbox When Releasing Gas Pedal
slawek5t 11517 10
What causes rhythmic knocking from the gearbox area in a Golf 3 1.9 TDI 1Z when lifting off the accelerator?
The most likely cause is a worn inner driveshaft/CV joint, not the engine or a dual-mass flywheel. One reply advised checking gearbox oil and internal joints, and the original poster later confirmed that one of the joints had grit and was damaged. After replacing both joints, the knocking disappeared and acceleration vibrations were reduced [#16215395][#16286641] A dual-mass flywheel was also ruled out for this 90 hp 1Z Golf 3 [#16218328]
  • #1 16215125
    slawek5t
    Help: 6
    Rate: 32
    Hello. I have a problem with my Golf 3 engine 1.9 tdi 90 km 1z.
    Well, for some time something is knocking. The stops come from where the gearbox is from.
    Knocking rhythmically when I let go gas while running on any race.
    When I add the gas, the claps are silent. It's okay at ease.
    What could it be? Knocking loudly and rhythmically.
  • #2 16215329
  • #3 16215356
    slawek5t
    Help: 6
    Rate: 32
    The knocks are only on the run.
  • #4 16215395
    moto-kord
    Help: 137
    Rate: 505
    Check the oil level in the gearbox, it would be good to unscrew the drain plug and see
    is there no filings, checking internal joints.
  • #5 16215454
  • #6 16215464
    robokop
    Help: 1763
    Rate: 6371
    celtic wrote:
    Dwumasa? The aborted invention was used in your engine.
    Yeah, two-thirty in 90-horse Golf 3. A fellow with a fantasy flew. Cushion, or pivot.
  • #7 16217679
  • #8 16218328
    robokop
    Help: 1763
    Rate: 6371
    Do not argue because you are not right. No 90-horse Golf 3 with 1Z engine, no dual-mass wheel.
  • #9 16218681
    moto-kord
    Help: 137
    Rate: 505
    celtic wrote:
    Once upon a miracle during assembly, my ring fell and the needles in the inner wrist were scattered
    There are no such joints in this.
  • Knocks returned after gearbox mount replacement at 280 Nm load
    #10 16218961
    slawek5t
    Help: 6
    Rate: 32
    As far as I know, the two-player has a golf III 110KM, and my 90KM does not.
    robokop wrote:
    Cushion, or pivot.
    I have changed the cushion on the chest recently. The knocks stopped for 2 days and then they came back again.
    I have not tested joints yet.
    I will add that my golf is a bit underlined.
    It now has about 125HP and 280 NM.
    I changed the injectors from 110 hp and made a chip for these injections. Turbo set at 1.25 bar.
  • #11 16286641
    slawek5t
    Help: 6
    Rate: 32
    Hello. Problem solved.
    One of the wrists got sand and he broke through it :)
    I exchanged two and now there is silence.
    In addition, the car generates a lot less vibrations during acceleration :)
    Thank you for the hints.
The discussion revolves around a rhythmic knocking noise originating from the gearbox area of a Golf 3 with a 1.9 TDI 90KM 1Z engine when the gas pedal is released during driving. Initial suggestions include checking for play in the crank or connecting rod, inspecting the gearbox oil level for filings, and examining internal joints. The user notes that the knocking ceased temporarily after replacing a cushion but returned, and mentions modifications to the engine, including upgraded injectors and turbo settings. Ultimately, the issue was resolved by replacing two worn wrists that had accumulated sand, leading to a significant reduction in vibrations during acceleration.
