VW T4 2.5 TDI 98r. ACV 102HP: Gearbox Disassembly - Engine Removal & Tips to Avoid Damage
debu85 26394 5
  • #1 16811384
    debu85
    Colleagues or disassembling the transmission in VW T4 2.5 TDI 98r. ACV 102 hp it is necessary to pull the engine with the gearbox?
    You can suggest what to look for if you can do it without pulling the engine out of the building. Do you have to unscrew the magenches, unscrew the suspension from both sides? Is there something to pay special attention to, not to damage something?
    oktawian89
    Help: 52
    Rate: 444
    You lower the engine down slightly, at the same time deflecting it from the sleds.
  • #3 16811508
    debu85
    thanks for the response
    the exhale must be unscrewed, for example somewhere near the catalyst? if the engine is low enough that it can stay in place.
    the suspension on the left side must be completely unscrewed, or only the axle shaft, or the steering rod?
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    The engine hangs on the beam lying on the front belt, the engine you catch behind the eye over the injection pump (important). Half shaft left, shock absorber, more you do not need. He leaves without the slightest problem. I never pull out the right half axle. Good luck.
  • #5 16811910
    debu85
    ok. thanks friends for hints
  • #6 16812560
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    The replacement of the two-mass set, the clutch is made from 9 to 16 at the ready ;)
