VW T5 4Motion 2005 2.5TDI 130KM: Converting Front to Polift - Parts & Cooler Compatibility
puchalak 20214 6
  • #1 17004416
    puchalak
    Help: 12
    Rate: 229
    I have a motorhome made on the basis of T5 4Motion from 2005 with 2.5TDI 130KM. The car basically leaves the garage only for holidays and weekend getaways, the mileage is quite decent, so I think I will have many years. As the front of the car qualifies for painting, I dreamed of transforming it into a polift version. As far as I know, it should be mentioned
    mask
    fenders
    Bumper
    Fixtures
    Grill
    Front strap
    beam
    These things are obvious to me, but apparently a set of coolers also needs to change, which I can't understand. I do not know if everyone (cooler, IC, evaporator, I think support)
    I can't understand the need to replace the coolers. I wonder if:
    1. Connectors coolers will fit? (in lift versions the AXD engine probably did not exist anymore)
    2. Are the old and new type headlamp plugs "compatible"
    3. Do you need to prepare any more parts?
    Added after 2 [hours] 14 [minutes]:
    I searched the internet and found the following.
    Neither the fenders nor the radiators are replaced in any way.
    You can leave the old front belt - the downside is the need to earn plates to fix the headlights. The headlight plugs remain the same, you just need to reposition some pins.
    The case looks quite good, because you need to replace the bonnet, bumper, dummy, beam, lamps and optional front belt.
    If someone experienced would like to verify it - I would be extremely grateful.
  • #4 17074944
    puchalak
    Help: 12
    Rate: 229
    Thank you very helpful movie. Although he mixed me up a bit. It seems to me that they do not t5 lift, but t6. I don't know why they change the fenders.
    https://www.youtube.com/watch?v=9JmkkNqleDc
    this is more of a drummer change - the one I plan. :D
  • #5 17076701
    dizba
    Help: 239
    Rate: 808
    Make some documentation. Maybe I'll decide?
  • Facelift swap needs hood, bumper, grille and lamps only
    #6 19290822
    robertstanislawski
    Hello, I worked in the Netherlands with a friend vw t5 with a 2.5 r5 engine ... you replace the hood, complete bumper, lamps (you need two rectangular plates for lamps because they have different bottom handles, that's all. [/ B]
    puchalak wrote:
    I have a motorhome made on the basis of T5 4Motion from 2005, 2.5TDI 130KM. Basically, the car leaves the garage only for holidays and weekend trips, the mileage is quite decent, so I think it will be with me for many more years. As the front of the car qualifies for painting, I dreamed of converting it into a facelift version. As far as I know, it should be replaced
    The mask
    Mudguards
    Bumper
    Lamps
    Grill
    Front belt
    The beam
    These things are obvious to me, but apparently a set of coolers also needs to be changed, which I cannot understand. I do not know if all (cooler, IC, evaporator, probably support)
    I cannot understand the need to replace the coolers. I wonder if:
    1. The connections of the coolers will fit? (in lift versions, the AXD engine probably did not exist anymore)
    2. Are the old and new headlight plugs "compatible"
    3. Are there any more parts to be prepared?
    I have searched the internet about this and figured out the following.
    Neither the fenders nor the radiators are replaced by any means.
    You can leave the old front apron - the downside is the need to add plates to fix the headlights. The headlight plugs remain the same, you just need to translate some pins.
    So the case looks quite good, because you need to replace the hood, bumper, grille, beam, lamps and optionally the front belt.
  • #7 19290926
    puchalak
    Help: 12
    Rate: 229
    Thanks. It's been almost 3 years after I converted.
The discussion revolves around converting a 2005 VW T5 4Motion with a 2.5TDI 130KM engine to a facelift (polift) version. The user seeks advice on necessary parts for the conversion, including the front mask, fenders, bumper, fixtures, grill, front strap, and beam. There is confusion regarding the compatibility of coolers, connectors, and headlamp plugs between the old and new versions. Responses include links to forums and videos for guidance, with one user noting the need to replace the hood, complete bumper, and lamps, highlighting the requirement for specific rectangular plates for the lamps due to different mounting styles.
