VW T5 AXD Engine: Clearing Clearance & Proper Way to Adjust Eccentricity, Camshaft and Tensioner
pisior1987 19785 3
  • #1 16230068
    pisior1987
    Help: 12
    Rate: 351
    How to properly clear the clearance in this engine ??
    I have this description:
    How can this eccentricity be stretched 0.5Nm ??
    I also read in this forum that we first tighten the camshaft and then delete the slack:
    "1 block wal
    2 set the mark on the circle with photo
    3 put in the tensioner wheel
    4 put near the shaft
    3.4 do not tighten
    5 stretch the fight wheel to the RIGHT
    6 now slack correction and tighten the tensioner!
    7 turn the shaft "
  • #2 16230663
    GRZECHU111
    Rate: 20
    It's hard to measure these 0.5 Nm I twisted the eccentric with my fingers and turned and it was ok by no means the car came back
  • #3 18085786
    airzocho
    Rate: 27
    Can the camshaft timing play on the T5 2.5TDI be cleared without taking the engine apart?
    I suspect that I have gently tensioned the tooth compensation gap. I wonder if I can make a correction after the car is already assembled? The car smokes an arrow and drives well but it seems to me that something is too much noise from the timing wheels.
  • #4 21399199
    LAMBDA
    Help: 6
    Rate: 38
    Hi, I know it's been a long time, but do you remember if you were able to adjust the backlash of the gearbox without reinstalling the locks and dismantling?
