Sony Bravia - Continuous display in the upper left corner of AV2 input.
wrobelj 6939 10
How do I turn off the AV2 overlay on a Sony Bravia when using a DVB-T decoder connected through AV2, and is a vertical red line on the screen a matrix defect that needs service?
Press the first button on the left from the top on the remote to hide the AV2 display [#16815805] The vertical red line is most likely a damaged matrix; one reply says the matrix should be replaced and it is not really a DIY fix [#16815805][#16815874] The original poster later reported that the AV2 overlay disappeared and the matrix was replaced for about PLN 200 [#16816300][#16816533]
  • #1 16814439
    wrobelj
    Rate: 54
    Hello! I have a Sony Bravia KDL-32U3000 TV and a DVB-T decoder connected to it. The decoder is connected to the EURO input AV2 socket. There must be a decoder because the TV has a decoder, but it only decodes MPEG-2. After turning on the TV and the decoder, the word AV2 is displayed on the screen in the upper left corner, and under it a circle with an arrow and the word 2. I do not know how to turn it off, because these are subtitles on a black background and occupy the screen a bit. Second question: on the right side, approx. 12 cm from the side edge, a vertical red line, approx. 3 mm wide, shines on me, is it a matrix defect, can it be removed by yourself or must be serviced. Thank you for the answers.
  • #2 16814512
  • #3 16815215
    wrobelj
    Rate: 54
    If they wrote, I would not write. Unless you have a different instruction.
  • #4 16815475
  • #5 16815775
    wrobelj
    Rate: 54
    And they drew and wrote what it is, but did not write how to turn it off so that it would not be displayed.
  • #6 16815805
    andpol 33
    Help: 514
    Rate: 1148
    The first key on the left from the top on the remote control. The red line is probably a damaged matrix.
  • #7 16815867
    Spartan33
    Help: 41
    Rate: 98
    Upload a photo of the strip that is on the matrix.
  • #8 16815874
  • #9 16816300
    wrobelj
    Rate: 54
    Many thanks for the hint andpol 33. It worked and there is more screen. Regards. And as for this strip, the TV has been working since morning and around 17:00 the strip disappeared. We'll see what happens next. Dear Mr. mihal2002, instead of writing blank posts, one could write as andpol 33 did and it would be in trouble.
  • #10 16816521
  • #11 16816533
    wrobelj
    Rate: 54
    The AV2 display was removed and the matrix was replaced (cost about PLN 200)
The discussion revolves around a Sony Bravia KDL-32U3000 TV experiencing a persistent display issue on the AV2 input, showing the label "AV2" along with a circle and the number "2." Users suggest checking the remote control for a solution, specifically the first key on the left from the top. The original poster later confirms that the display issue was resolved. Additionally, a vertical red line on the screen raised concerns about a potential matrix defect, which was initially thought to require service. However, the line disappeared after some time, indicating it may not have been a permanent issue. One user mentioned that replacing the matrix would cost around PLN 200 if needed.
