Best Multimeter under PLN 100 for Amateur Use: Home, Car & RC Modeling - Unita & Banggood Options
Norbas78 8190 16
What multimeter under PLN 100 is worth buying for amateur home, car, and RC use, and are there better options than cheap supermarket meters or local UNIT models?
The thread leans toward the ANENG AN8008/AN8009 as the best budget choice under PLN 100, with the 8009 being the newer version with a slightly larger range and an extra thermometer. Both are automatic-range meters, and users report that they work well, have a fast continuity beep, and can measure LEDs; one user also says they run on common batteries. The main downside mentioned is the unusual, tiny fuse format, though it is still considered acceptable. If you want the simplest recommendation from the replies, buy the ANENG 8009; if you want a cheaper but still solid choice, the 8008 was also recommended [#16815236] [#16815996] [#16816544] [#16816574] [#16820457] [#16820566]
  • #1 16815041
    Norbas78
    Rate: 79
    I would like to buy a multimeter for typical amateur applications, say up to PLN 100. I don't know how much attention is worth in this amount.
    Until now, I have used two supermarkets, 15-20 zlotys, but recently when I returned to rc modeling and compared their indications, it turned out that everyone shows something different and the indications fluctuate, e.g. by 0.7V ...
    I decided to buy something better and above all more accurate which will show true indications.
    I want to use it for both home and car applications.
    can you ask for advice what is worth buying in my amount?
    If the same amount but something better can be bought abroad, e.g. for banggood, please indicate something worth attention
    link
    I was in an electronics store where I was advised of some Unita for PLN 90 but I decided to ask on the electrode first :-)
  • #2 16815051
    kryst
    Help: 12
    Rate: 40
    I personally would take this one link , too bad there is no inductance measurement.
  • #3 16815236
    alien90fr
    Help: 100
    Rate: 107
    I will recommend you aneng an 8008 for less than 100 small handy, I am doing well.
  • #4 16815323
    Norbas78
    Rate: 79
    Which of the above has more functions and better accuracy?
    I don't know anything about multimeters because I only used market ones, but I would like it to be accurate and development, i.e. have a lot of functions that will be useful when I deepen my knowledge and skills.
    PS. It does not have to be tiny, the size does not bother me because it will be used stationary and a larger display is also a plus for me with backlighting if possible.
    AnengAn8009 better than 8008? The price difference is small.
    In turn, the one from the first proposal is larger and I do not know what to call it, but in the picture I see that it has a sensor on top that the person from the photo puts on the electrical outlet ... is it measuring the value in the socket without using cables?
  • #5 16815461
    alien90fr
    Help: 100
    Rate: 107
    This sensor detects line voltage. Useful when you want to check where the wire in the wall goes.
    Added after 29 [minutes]:
    Unit 139c also has this feature but it is much more expensive.
  • #6 16815996
    Norbas78
    Rate: 79
    Ageng 8009 has an additional thermometer in the set ...
    Hmmm ... I don't know which one to decide myself ... ot ... if you don't know it, it's hard to make a decision.
  • #7 16816436
    alien90fr
    Help: 100
    Rate: 107
    I have the 8002 model and I also got a thermometer and a bag for storing the meter ?
  • #8 16816488
    Norbas78
    Rate: 79
    Due to the small amount of possible knob settings, I understand that these Agengas are automatic?
    How with the accuracy of the indications? Will it not work like my two supermarkets?
  • #9 16816544
    alien90fr
    Help: 100
    Rate: 107
    Yes they are machines. There are a few videos about these meters on yt you can see with accuracy.
  • #10 16816553
    Norbas78
    Rate: 79
    And how do they relate to popular UNITs?
  • #11 16816574
    alien90fr
    Help: 100
    Rate: 107
    It's hard for me to say because I haven't had the opportunity to commune with the unit. I wanted to buy ut 61e but I found this aneng and I chose it and it works well overall with normal batteries that can be bought almost anywhere. Led measurement also works even blue. The speed of the "squeak" continuity test is also at a good level
  • #12 16820457
    Simon79
    Help: 29
    Rate: 397
    The downside of aneng is an unusual fuse, but overall it is ok.
  • #13 16820533
    alien90fr
    Help: 100
    Rate: 107
    Yes it's true fuses are tiny but it's good though they are 2 chociaż
  • #14 16820566
    Norbas78
    Rate: 79
    I ordered version 8009. I expect that as newer it will not be worse than 8008. According to reviews and opinions on YT that each subsequent version was not worse and it brought something new :-)
    Are these unusual fuses somewhere to get? Yes to the store.
    I hope that, as in the opinions, the meter will be accurate. At the moment it is important to me because at the beginning I will use it mainly for checking and measuring Li-Po and Li-ion packets and correcting indications in chargers.
  • #15 16820639
    alien90fr
    Help: 100
    Rate: 107
    I didn't look for fuse for it but I hope you can get it somewhere.
  • #16 16820647
    krakarak
    Help: 681
    Rate: 1841
    @ alien90fr you decide what meter you have and what you recommend - 8002 or 8008.
  • #17 16820681
    alien90fr
    Help: 100
    Rate: 107
    I have already written that I have 8002 and a colleague chose 8009 which is newer with a larger range but in terms of external and internal appearance practically the same.
✨ The discussion revolves around selecting a multimeter for amateur use under PLN 100, suitable for home, car, and RC modeling applications. Users recommend various models, highlighting the Aneng AN8008 and AN8009 for their accuracy and functionality. The Aneng meters are noted for being automatic with a good range of features, including temperature measurement in the AN8009. Concerns about the accuracy of supermarket multimeters lead to a desire for a more reliable device. The Unita brand is also mentioned, but specific models are less favored compared to Aneng. Users discuss the importance of features like inductance measurement and the ability to measure line voltage without direct connections. The discussion concludes with a user ordering the AN8009, expressing hope for its accuracy and functionality.
TL;DR: Under PLN 100, users report supermarket meters drifting by 0.7 V; “I want to use it for both home and car applications.” [Elektroda, Norbas78, post #16815041]
Why it matters: This FAQ helps hobbyists choose an accurate, affordable multimeter for home, car, and RC tasks without guesswork.
What’s the best multimeter under PLN 100 for amateur use?
From user experience, ANENG AN8008 is a strong pick under 100 PLN for general DIY and hobby work. It’s small and handy. If you prefer imports, Banggood options were part of the discussion. Choose based on needed features like temperature or NCV. [Elektroda, alien90fr, post #16815236]
ANENG AN8008 vs. AN8009 — which should I buy?
A user chose AN8009, described as newer with a larger range, yet very similar externally and internally to earlier models. If prices are close, AN8009 offers the broader range, while AN8008 keeps value tight under 100 PLN. [Elektroda, alien90fr, post #16820681]
Is the PEAKMETER PM890C worth considering?
Yes, one participant would pick the PM890C model; it’s labeled 6000 counts, which indicates display resolution class. It lacks inductance measurement per the note, so ensure that feature isn’t critical for you. [Elektroda, kryst, post #16815051]
Do these meters have non-contact voltage (NCV) detection?
Yes. The highlighted top sensor detects line voltage, useful for tracing wires in walls. Some higher-tier Uni-T models like UT139C also include NCV but cost more. NCV helps quick safety checks before contact probing. [Elektroda, alien90fr, post #16815461]
Are ANENG meters autoranging?
Yes. Community feedback notes they’re autoranging, which reduces knob positions and speeds setup for beginners. “There are a few videos… you can see with accuracy,” one user added, encouraging hands-on verification. [Elektroda, alien90fr, post #16816544]
How accurate are budget meters versus supermarket models?
The thread-starter observed 0.7 V variation between supermarket meters, motivating an upgrade. Moving to ANENG or PM890C aims to improve stability for home, car, and RC needs. Expect tighter readings than the cheapest units. [Elektroda, Norbas78, post #16815041]
Does ANENG support LED testing and fast continuity beeps?
A user reports LED testing works, including blue LEDs. Continuity test speed was described as good, which helps fast troubleshooting. “Led measurement also works even blue,” they wrote, summarizing real use. [Elektroda, alien90fr, post #16816574]
Does ANENG AN8009 include a thermometer?
Yes. The buyer highlighted AN8009’s added thermometer in the set, which helps with electronics and RC pack checks when thermal context matters. Consider it if temperature is on your checklist. [Elektroda, Norbas78, post #16815996]
What accessories came with ANENG AN8002 in this thread?
One user received a thermometer and a storage bag with AN8002. Bundles can vary by seller, so confirm the listing if those extras matter for your kit. [Elektroda, alien90fr, post #16816436]
Are ANENG fuses standard and easy to replace?
A participant called the ANENG fuse “unusual,” implying sourcing can be trickier than standard sizes. Plan ahead by checking spare availability when purchasing, especially if you measure current often. [Elektroda, Simon79, post #16820457]
Can I find replacement fuses locally?
One user hadn’t searched yet and hoped they’re available. Treat fuse sourcing as an edge case: verify size and type before heavy current work to avoid downtime. [Elektroda, alien90fr, post #16820639]
How does ANENG compare to popular UNI‑T models?
A user considered the UNI‑T UT61E but chose ANENG. They couldn’t offer a head‑to‑head comparison, yet praised ANENG’s normal batteries, LED testing, and continuity speed. [Elektroda, alien90fr, post #16816574]
Do ANENG meters use common batteries?
Yes. Feedback states they run on normal batteries available almost anywhere. That lowers running costs and keeps your meter ready without special cells. [Elektroda, alien90fr, post #16816574]
Where can I shop these meters online?
Banggood was referenced for foreign purchase options with many budget multimeters. Compare shipping times and bundles, then match features like NCV or temperature to your needs. [Elektroda, Norbas78, post #16815041]
What does “6000 counts” mean in practice?
The PM890C listing mentions 6000 counts. That number signals the resolution tier of the display readout class. For hobby use under PLN 100, 6000 counts is a practical step up from supermarket tools. [Elektroda, kryst, post #16815051]
How do I measure Li‑Po/Li‑ion pack voltage safely with a new meter?
  1. Set the meter to DC volts (autorange if available).
  2. Touch probes to the pack’s main terminals: red to positive, black to negative.
  3. Read the total pack voltage and compare with charger readings for calibration checks. “Use case: checking Li‑Po/Li‑ion packets” was the buyer’s priority. [Elektroda, Norbas78, post #16820566]
