High Ping T-Mobile Internet: Huawei B525 Router, Kielce, TP-Link Antennas TL-ANT2408CL Solution?
daryk1995 7530 7
  • #1 16818939
    daryk1995
    Hello, I am testing Internet from T-mobile with a Huawei B525 router for about 2 weeks, I have an option up to 20 Mb / sio as much as I actually download, so ping from 17 to 23 is tragic, usually above 100, while at night it is ok and is then about 35-70. I use it in Kielce. I was thinking about mounting some TP-Link antennas TL-ANT2408CL, but will it help stabilize the ping?
  • #3 16819354
    geniusm
    Help: 70
    Rate: 49
    Rather, it looks overloaded BTS. In addition, check where you have the transmitter because you may find that around the corner and the antenna can not do anything.
  • #4 16819365
    daryk1995
    The transmitters are actually right next to them; / So nothing can handle these Pingas during these hours? Worth trying on other networks? I tried in Plus but similar matter, so Play remains.
  • #5 16819373
    KOCUREK1970
    Help: 3862
    Rate: 5490
    daryk1995 wrote:
    Play remains
    You think that they are better at them (optimist ...).
  • #6 16819388
    daryk1995
    Probably the same; / I was still thinking about the typical radio internet, but I do not know what the connection would look like, I would generally install a cable or fiber optic cable, but the owner does not want to agree and therefore I am looking for some alternative to June, and I care mainly about ping.
  • #7 16819401
    KOCUREK1970
    Help: 3862
    Rate: 5490
    Radio similar (indicated by the assumed topics here).
    In general, net GSM and net radio for online games are not suitable (under certain conditions).
  • #8 16819834
    matek451
    Help: 4352
    Rate: 5808
    What kind of street in Kielce, which BTS do you use and on what LTE band? T-Mobile in Kielce uses LTE1800NetWorks and its own LTE800 and LTE2600 as well as LTE band aggregation. Did you force these bands in turn on the B525 and aggregate LTE2600 + 1800, LTE2600 + 800 or LTE1800 + 800?
The discussion revolves around high ping issues experienced with T-Mobile Internet using a Huawei B525 router in Kielce. The user reports a ping range of 17 to 23 ms during optimal times, but it often spikes above 100 ms, particularly during peak hours. Suggestions include checking the proximity of the transmitter and considering the potential overload of the base transceiver station (BTS). The user contemplates using TP-Link TL-ANT2408CL antennas to stabilize the ping but is uncertain about their effectiveness. Other users mention the limitations of GSM and radio internet for online gaming and inquire about the specific LTE bands being utilized by T-Mobile in the area, suggesting that band aggregation might improve performance.
