T-Mobile Home Internet: Poor Transmission with Huawei B529 Router - Antenna & WiFi Solutions
zeeon 6429 15
How can I improve slow T-Mobile Home Internet on a Huawei B529 using external antennas and better Wi‑Fi coverage?
To improve it, first test the router on each LTE band and band combination to see which BTS it actually uses, and check DL/UL plus signal quality like SINR; in this case the reported LTE800, LTE1800, and LTE1800+800 results were weak and congested, and aggregation did not start [#17326697][#17431447] The cable from the roof must be 50 Ω, not 75 Ω [#17326674] If you do install antennas, use two antennas for MIMO 2x2, ideally wideband 800/1800 MHz directional antennas such as the ATK-502, and point them at the BTS that gives the best parameters [#17433707][#17433953] However, the antenna will only help if the path has enough Fresnel-zone clearance; if the clearance is poor, the antenna may not improve anything [#17434019] The thread also suggests that in this location 3G UMTS2100 HSPA+ DC might even be faster than the current LTE setup, so that should be tested too [#17431447] For indoor coverage, separate the Wi‑Fi problem from the cellular link and add an AP if needed, but the main bottleneck is the poor LTE reception/signal quality [#17326697][#17431447]
  • 75 Ω coax and external antenna feasibility for B529 router
    #1 17326595
    zeeon
    Hey,
    I have home internet from T-mobile with a Huawei B529 router (this cube).
    Unfortunately, it works very slowly - in gusts in Speedtest download and upload equally - 4-5 Mb / s, and often slower - 2-3. The pages barely walk, and I can dream of HD streaming.
    I would like to install additional antennas on the roof of the house. I have coaxial cables (2 more free) 75 Ohm from the utility room to the roof. I would also like to increase the wifi signal at home (ground floor + first floor).
    And now - do I think right:
    1. I'm not sure if 75 Ohm is a good cable - but it's going to be difficult to bring something new to the roof right now, without interfering with the walls
    2. I am close to the transmitters: 1.3 km and 2.6 km (picture attached) - but the internet is poor
    3. I would like to mount 2 x atk 10
    4. I could mount the router in a utility room, connect the network transmitter, connect the AP.
    Will do the trick? Something will improve it?
  • Test individual LTE bands and BTS signal parameters
    #3 17326697
    matek451
    Help: 4352
    Rate: 5808
    As a friend advises, first test on individual bands to check which BTS the router connects to and what signal and speed parameters. We always show DL / UL. You should log in to the closer one but it is different. On both LTE1800NetWorks and LTE800 T-mobile and their aggregation. You will also need to check how these BTSs work on individual bands near them in your direction with optimal signal parameters. The directional antenna allows you to choose the less loaded. The B529 has a battery so it's not a problem.
  • LTE 800 and 1800 band test screenshots
    #4 17326772
    zeeon
    Thanks for the answer.
    I already have the app installed. In the evening I will do tests on different bands and send screenshots.
    Added after 5 [hours] 8 [minutes]:
    So:
    For LTE 800:
    T-Mobile Home Internet: Poor Transmission with Huawei B529 Router - Antenna & WiFi Solutions T-Mobile Home Internet: Poor Transmission with Huawei B529 Router - Antenna & WiFi Solutions
    For LTE 1800:
    For LTE 1800 + 800
  • #5 17331403
    zeeon
    And how does it look like?
  • #6 17331447
    matek451
    Help: 4352
    Rate: 5808
    LTE800 tragedy from BTS-a Cerekwica-Mrowino. Signal weak, low SINR band clogged. LTE1800 from Rolna 41, weak signal, low SINR DL, UL or BTS stuck. LTE180 + 800 aggregation does not start. Connection only to LTE800 Cerekwica. It doesn't connect to Bytkow where there are LTE1800 + 800 bands. It is possible that the chance for a normal internet is to check how it works under BTS Bytkowo. You position yourself about 200-300m from it in your direction and on the B529 you force LTE1800, LTE800 and LTE1800 + 800 one by one, check the parameters, CID and speedtest. LTE800 is also on BTS near Rolna, so check the same under it. It doesn't look good yet. It is possible that 3G may be the fastest with UMTS2100 HSPA + DC on Rolna St., check them at your place and under this BTS.
  • #7 17432950
    zeeon
    So:
    Some time ago I took the router with me and made measurements at a distance of about 200m from the BTS.
    The following results:
    Bytkowo:
    LTE 800
    LTE 1800
    LTE 1800 + 800
    AGRICULTURAL:
    LTE 800
    LTE 1800
    LTE 1800 + 800
  • #9 17433520
    zeeon
    matek451 wrote:
    There is no madness, weakness for me. DL> UL but generally slow and low SINR.
    It's not good. But is it worth investing in an antenna? Because it's better than at home.
  • #10 17433570
    szy_mat
    Help: 8
    Rate: 18
    Without forging the walls, you can set up the router at the antenna itself, and then import the twisted pair cable (or WLAN after the coaxial cable if you do not have twisted pair, the "wooden" solution works for a short distance), or play matching impedance of the transmission line (I do not recommend, a lot of fun , finally you will probably understand "why Edison preferred DC"). :)
  • #11 17433707
    matek451
    Help: 4352
    Rate: 5808
    800 and 1800MHz wideband antenna, e.g. ATK-502 from Telkob. Two pieces because it's MIMO2x2. You will check Bytkowo and Rolna pointing at them.
  • #12 17433917
    szy_mat
    Help: 8
    Rate: 18
    @ matek451, I doubt that an antenna for such a wide bandwidth would be a good choice, unless it is actually two antennas with a crossover network ... if not, the gain of such a miracle will be not much better than the antenna built into the modem ... Fresnel zone between the possible antenna on roof and is BTSem? If so, any shit on the roof you put on and you will have a good range, if there is none, then in 1800 or 2600 you will not improve it with any antenna, then try an antenna with a good gain (yagi?) At 800.
  • #13 17433953
    matek451
    Help: 4352
    Rate: 5808
    And do you know what the logarithmic periodic antenna looks like and works? These antennas work in a wide range and have a gain of 9-11dBi, minus cable losses, quite wide radiation angles associated with their construction. For this transfer of signal intake to the outside. The distances are not great, my friend has no choice. Without the LTE800 antenna, the router logs in to the crowded BTS Mrowino. On LTE1800 to Rolna. Generally there is a lime in T-mobile but it is becoming the norm at this operator. Especially on BTS with bare LTE800. This is not an operator for this location if someone cares about speed.
  • #14 17434011
    szy_mat
    Help: 8
    Rate: 18
    In theory, I know, in practice I have never used such antennas for anything above 450MHz, so I haven't had the opportunity to check. One thing is certain - for 1800, as on any microwave band, the most important is the Fresnel zone.
  • #15 17434012
    zeeon
    Mount the antennas on the roof and pass through a ventilation chimney with cables.
    Only if I buy good antennas, because I don't spend 300 zlotys smiling and something that won't help ;)
  • #16 17434019
    szy_mat
    Help: 8
    Rate: 18
    @zeeon, check at least through link.ubnt.com (better via ve2dbe.com Radio Mobile, but this program is complicated), whether from the height of the house (you set at the point on the map) to the height of the BTS (select say 30m) you have at least 40% Fresnel zone clearance. If not, I will say in advance that it will not help.
The discussion revolves around the performance issues of T-Mobile Home Internet using a Huawei B529 router, which is experiencing slow speeds (2-5 Mb/s) and poor transmission quality. The user seeks solutions to enhance internet connectivity by installing additional antennas on the roof and improving WiFi signal throughout the house. Responses suggest testing different LTE bands (800 and 1800 MHz) to identify optimal connections, using directional antennas for better signal reception, and ensuring proper cable impedance (50 Ohm recommended). The importance of the Fresnel zone for antenna placement is emphasized, along with the potential benefits of using high-gain antennas like the ATK-502. Users share their testing results and discuss the challenges of achieving reliable internet speeds with T-Mobile in their area.
TL;DR: For T‑Mobile Home Internet on Huawei B529, to fix slow speeds, lock LTE 800/1800, test 200–300 m from the BTS; "LTE800 is clogged." [Elektroda, matek451, post #17331447]
Why it matters: This helps you pick the right band and antenna before spending money, improving stability and throughput.
How do I fix slow speeds on T‑Mobile Home Internet with a Huawei B529?
Force the router to LTE 800 and LTE 1800 individually. Run DL/UL tests and note RSRP and SINR. A directional antenna helps you choose the less‑loaded BTS. Test CA (1800+800) after identifying the best band. [Elektroda, matek451, post #17326697]
Is 75‑Ohm coax acceptable for LTE antennas?
No. LTE modems and antennas expect 50‑Ohm lines. Using 75‑Ohm increases mismatch loss and degrades signal quality. Replace with proper 50‑Ohm coax for reliable results. "The cable is bad, it must be 50 Ohm." [Elektroda, makosuu, post #17326674]
Which external antenna should I buy for the B529, and how many?
Use two wideband 800–1800 MHz antennas such as ATK‑502. The B529 is 2x2 MIMO, so two identical antennas are required. Aim each toward candidate BTS sites to compare performance. [Elektroda, matek451, post #17433707]
How do I lock LTE bands on the Huawei B529?
How‑To: 1) Install Huawei Manager, 2) Log into the router, 3) Force LTE 800, LTE 1800, and 1800+800, then run DL/UL speed tests. Capture screenshots for each band to compare. [Elektroda, makosuu, post #17326674]
Carrier aggregation (1800+800) won’t start. What’s going on?
Your tests showed aggregation did not initiate and the router stayed on LTE800. That reflects local network configuration and loading on nearby BTS. In this location, CA did not engage despite testing. [Elektroda, matek451, post #17331447]
Are my nearby towers overloaded or is the signal just weak?
Results indicated low SINR and slow throughput, with DL faster than UL. As one expert summarized, “slow and low SINR.” That pattern suggests congestion more than pure coverage. Low SINR cuts spectral efficiency sharply. [Elektroda, matek451, post #17433348]
Should I test near the BTS before buying antennas?
Yes. Position about 200–300 meters from the target BTS in your direction. Force LTE1800, LTE800, then 1800+800 and record speed and CID. This isolates network capacity from home‑site variables. [Elektroda, matek451, post #17331447]
How should I aim the antennas (Bytkowo vs. Rolna)?
Aim at Bytkowo and Rolna and compare results on LTE800 and LTE1800. Use two matched antennas for 2x2 MIMO. Choose the direction delivering higher SINR and consistent DL/UL. [Elektroda, matek451, post #17433707]
Could 3G HSPA+ DC on UMTS2100 be faster than LTE here?
Possibly. When LTE800 is crowded and CA fails, UMTS2100 HSPA+ DC can outperform LTE at peak hours. Test at home and near the Rolna BTS. “3G may be the fastest.” [Elektroda, matek451, post #17331447]
Can I place the router near the antenna and run Ethernet back?
Yes. Mount the router at the antenna location, then run twisted‑pair Ethernet into the house. WLAN over coax is a short‑distance workaround but not ideal. “Matching impedance… I do not recommend.” [Elektroda, szy_mat, post #17433570]
How do I check Fresnel zone clearance quickly?
Use link.ubnt.com or Radio Mobile (ve2dbe.com). Input house and BTS heights to plot the path. Ensure at least 40% Fresnel clearance to benefit from higher bands. [Elektroda, szy_mat, post #17434019]
What speeds should I expect without an external antenna here?
Reported speeds were about 4–5 Mb/s down and up, often 2–3 Mb/s. At those rates, HD streaming struggles and pages load slowly. That reflects congested LTE800 service. [Elektroda, zeeon, post #17326595]
Is T‑Mobile a good operator choice at this location?
Expect weaker performance where local BTS mainly offers LTE800 and shows congestion. An expert noted this operator may not meet speed needs here. Consider alternatives if speed is critical. [Elektroda, matek451, post #17433953]
