Saab 9-3 Sport: Folding Mirror Malfunction, PDM Tester Results, Ignition Switch Issue
7689 6
  • #1 16821207
    seat21
    Help: 151
    Rate: 399
    everything is correct tech2 and to do pdm must be programmed, only then you can check the lock
  • #3 16826330
  • #4 16826363
    seat21
    Help: 151
    Rate: 399
    the whole saab, but the plus is that there are no pins, approval and work
  • #5 16826404
    seat21
    Help: 151
    Rate: 399
    something like that
    • Saab 9-3 Sport: Folding Mirror Malfunction, PDM Tester Results, Ignition Switch Issue 2007x3.jpg (121.56 KB) You must be logged in to download this attachment.
  • #7 16830818
The discussion revolves around a malfunction in the folding mirrors of a Saab 9-3 Sport, where the right mirror fails to fold while the left one operates correctly. The user connected a PDM tester, which indicated an unknown environment identifier error, suggesting that the PDM may have been replaced from another vehicle. After programming the new PDM with the correct VIN, the mirror functionality was restored. Additionally, the user faced an ignition switch issue where the key could not be turned unless the clamp was removed and reinstalled. The conversation also touched on the presence of an amplifier under the driver's seat in a vehicle converted from right-hand drive, with a request for a wiring diagram.
