Renault Clio II: Low Beam Headlights Not Working, High Beam & Turn Signals Fine, Fuses Checked
miraz5 14502 4
  • #1 17415727
    miraz5
    Hello, I have a problem with low beam or low beam. To turn on the low beam, I turn the handle on the steering wheel and the low beam does not light up and the position lights remain. High beam, turn signals, everything is fine. After turning to the dipped beam on the dashboard, the indicator light from the dipped beam lights up as if everything was fine, but the lights do not come on. I checked the fuses and they were fine. On the Internet I found relays from the lights under the steering wheel above the left leg. I swapped them with myself, wanting to check if they would work like that, but nothing like that. I am enclosing a photo with these relays because maybe they are not from the lights and I was playing with something else in my ignorance.
    • Renault Clio II: Low Beam Headlights Not Working, High Beam & Turn Signals Fine, Fuses Checked 40517784_309097353198577_5670493674203512832_n.jpg (42.14 KB) You must be logged in to download this attachment.
  • #2 17415736
    darfur5
    Help: 267
    Rate: 1715
    Did you check the bulbs themselves?
  • #3 17415776
    miraz5
    Yes, I did another one, but still nothing.
  • #5 17418666
    goldwinger
    Help: 535
    Rate: 2101
    Shifter checked?
