Peugeot 508 2.0hdi 140km 2011 - Delayed reaction to gas, stop at 1500r
adrian881 12555 9
Why does my Peugeot 508 hesitate and stop responding around 1500 rpm when accelerating from idle, and what should I check if fixing the alternator regulator does not help?
After fixing the alternator regulator, the next thing to check is the fuel-pressure system: the in-tank fuel pressure sensor, the pump, and pressure regulation, because a bad sensor signal can make the ECU switch to a substitute pressure value and limit the engine to about 1500 rpm [#16824140] Unstable charging voltage can also disturb sensor operation, so replacing the regulator first was a reasonable step [#16823779] The recommended diagnosis is to connect PSA-specific diagnostics such as Planet 2000/Lexia and log live data during a road test, especially the freeze-frame and the commanded vs actual fuel pressure when the fault appears [#16824140][#16823779] If the pressures differ sharply or jump, that points to either the pressure sensor or the regulation circuit [#16824140] Because metal filings were seen in the fuel filter, the in-tank pump should also be checked and the fuel pressure measured [#16823779]
  • #1 16823528
    adrian881
    Hey
    This is my first forum post. So far I haven't found anything on the network that would correspond to the symptoms observed in my car, so please help.
    With each attempt to squeeze gas from idle, the pointer stops at around 1500rpm (repeatedly exactly in the same place) and after a while it is screwed for 3 thousand and further. After pressing the floor again it goes smoothly. After waiting 5 seconds the problem returns. I diagnosed my computer and now there is a charging error on the wallpaper, and in fact the battery voltage varies between 11v and 15.5v which is confirmed by squinting xenon. I plan to replace the regulator or regenerate the alternator. I have already checked egr and throttles, everything is clean, it works smoothly. The brake position sensor is also replaced (apparently there was a repair campaign for it). No other errors like fap error or check engine. In my version you do not need to replenish the factor, at least I could not find the tank. I do not want to blindly clean the fapa or exchange sensors, because I can not afford it and I do not have time for it and the turbo and clutch are already waiting in the blocks for replacement ... I wonder this repetition in the decrease in power in exactly the same range of rotation. I think that if the fap was clogged then the speed would wave or the power would drop overall. It could also enter safe mode.
    The question is, what to focus on if repairing the alternator fails to improve?
    PS
    I found a few more mistakes, which I associate with incorrect tension.
    1) preheating the candles
    2) seat heating
    3) errors of touch opening sensors
    I will also indicate that the car is equipped quite strongly, firing up the button, head up display, tactile opening, etc. Generally a lot of electricity.
    Sometimes, it actually happens that opening by touch does not work well, but this is associated rather with a weak key battery.
    The car burns nicely, revolutions do not wave, when it starts it collects nicely, on the highway also smoothly, except for the situation of rapid acceleration from below 1500rpm, then the response is delayed and as soon as the hydraulics clutter the pain clatters.
    Oils and filters replaced, the fuel pump is also not in the best condition (you can see swarf when changing the filter). Maybe someone had similar problems or can advise on what to focus on? I warn you that I can't change my car until I buy a second car so I hope that at least this hole in the turnover can be patched ...
  • #3 16823945
    adrian881
    Thanks for support. How can I measure the fuel pressure? Can I read it from the computer or do I need to install any sensor in the system?
    I am also skeptical about the necessity to pull out the film. We'll see what happens after the alternator is repaired. I read somewhere else that I may have some left soft uploaded, which may result in disruptions at work and the lack of a register of all errors, but this is only apparently. In addition, I am surprised by the repetition of disturbances in exactly the same range of rotations, which can be more indicative of a computer failure rather than strict mechanics ....
  • #5 16824375
    adrian881
    Hey
    Thanks for the extensive description. I will try to check it somehow. Yesterday the egr. On a cold engine, the problem remains, but I noticed today that after warming up there is no pronounced alloy on 1300-1400 orbits and throttling after adding gas at low speed also decreased. Rather, it can be described as a turbo hole.
    Still, he jumps cold. After reaching 1400obr there is a decrease in power followed by a sharp increase (pronounced jerk) and then the clatter of valves can be heard. I have the impression as if he was getting the right injection of fuel but he runs out of air and only when he turns on the turbo does he get a sharp power.
    Friday, I hope, solve the landing topic and see what's next. I will try to record this jump in revs and jerking gear when accelerating at low revs.
  • #6 16824447
  • #7 16824698
    adrian881
    Thanks! I will try to diagnose it better. Can you indicate where I could find reference parameters to compare? I don't know if my mechanic will catch a deviation. It would be best to show him how much it should be. Maybe it's better to borrow a computer and try to spot the differences yourself ...
  • #8 16824716
  • #9 16824851
    adrian881
    The mechanic has a pdl5500 interface, so I think he should be able to read the parameters. I also bought a lexie, but I can't cope with the installation on my old laptop ... mechanic or motoring enthusiast. I am only looking for tips on how to refine the fault search area and avoid exchanging everything in turn. I will answer as soon as I get more info. Thanks for the help. I already know more than yesterday so it was worth asking ;)
  • #10 16839929
    adrian881
    Voltage regulator replaced. The alternator is working correctly. Only the candle preheating error remained. Nothing has changed about the reaction to gas ... Now I will try to comprehend better diagnostics during work. Do you know where to find a tank for FAP fluid? In most models it should be next to the Right rear wheel, but I haven't found anything like that ... And this preheating error ...
The discussion revolves around a 2011 Peugeot 508 2.0 HDi experiencing a delayed reaction to gas, particularly stalling at around 1500 RPM before accelerating further. The owner has diagnosed a charging error with fluctuating battery voltage between 11V and 15.5V, leading to plans for replacing the voltage regulator or regenerating the alternator. Various components, including the EGR and throttle, have been checked and found clean. Suggestions from forum members include checking the fuel pressure sensor, as the consistent RPM issue may indicate a fault in the injection computer or fuel delivery system. The owner is also seeking guidance on measuring fuel pressure and finding reference parameters for diagnostics. After replacing the voltage regulator, the issue persists, prompting further investigation into the FAP fluid tank location and preheating errors.
