Burning TV Risk: Adding 1m RGB 5050 LEDs, 5v-12v Converter, USB Power - Hobbyist Inquiry
DawideuU931 10668 10
Can I power a 1 m RGB 5050 LED strip from a TV’s USB port using a 5V-to-12V converter without risking damage to the TV?
No — using the TV’s USB port to feed a 5V→12V converter for a 1 m RGB 5050 strip is not recommended, because the USB port current is likely too low and the real maximum for that TV is unknown, so you could overload or damage the port or the TV itself [#16825288][#16826121][#16825166] A 1 m strip with 45 LEDs is estimated at about 0.9 A at 12 V, while a typical USB port is only 5 V/500 mA (2.5 W), which is far below what you need even before converter losses [#16825288][#16826121] The simplest and safest solution is to use a separate 12 V supply; one reply suggests a cheap 12 V/2 A adapter instead of risking the TV [#16823906][#16825288] If you want the LEDs to turn on with the TV, a suggested workaround is to use the USB port only to energize a relay coil and switch the LED strip from a separate power supply [#16825084]
  • #1 16823836
    DawideuU931
    Since I am not quite experienced and I am a hobbyist in the field of electronics, I have a question.
    I would like to add 1m RGB 5050 LEDs (45LED RGB / 1m) for the TV, although I do not have a 12v power supply.
    I would like to use the built-in USB port on the TV and the 5v-12v converter.
    I am going to connect the 12V from the inverter to the tape controller. (INPUT: 12v max. 6A)
    Here, however, one question arises. Will such a TV with a USB port supply demanding power?
    A colleague said that it could burn the port, as well as the TV itself.
    Thank you for all the answers.
  • #2 16823906
  • #3 16823914
    oskar777
    Help: 76
    Rate: 243
    Give the TV model, maybe it is written in the documentation what the performance of this USB port is. Probably a colleague may be right.
    Oskar-info
    Gidzińskiego 24/1, Warszawa, 02-293 | Tel.: 501XXXXXX (Show) | Company Website: http://oskar-info.pl
  • #4 16824866
    maxipalia
    Help: 7
    If the USB port has a formal symbol (this funny badge) it must comply with all the requirements of the organization, which means it must be protected against overload. Possible damage may be the basis for warranty claims.
    This is a paraphrase of the opinion of an expert from around 2000 :)
    Maybe someone who still does on the site has more recent knowledge
    Regards
  • #5 16824981
  • #6 16825019
    DawideuU931
    Christophorus wrote:
    It is different to connect, for example, a USB stick or an external disk that meets certain norms and standards to such a USB port, and a "made in DIY" power supply is different. With this kind of constructions made sloppy, it worked easily to short-circuit and damage the port or the entire TV set.
    There will be no short circuits, but who knows ..
    The only thing I know about the TV is that it is the LG 26LK330, and the USB input has this wheel with this badge, which has 3 lines.
    MCR62 and a string of numbers write above the port.
    Apparently, you can burn the motherboard in the same way in a computer.
  • #7 16825084
    maxipalia
    Help: 7
    I totally agree, it's different ...
    But according to the USB (USB-IF, Inc.) standard www.usb.org
    Each (socket and plug) device bearing the logo must meet the requirements, i.e. also withstand the cutting / breaking of the cable.
    As for computers, asus boards that I had as well as the current intel are completely protected and disable the port in the event of overload, as LG did, I do not know and do not urge.
    I have a suggestion for the author of the post ...
    If you want LEDs to turn on together with the TV:
    plug the power supply of the relay coil into the USB port and steal the power supply from the TV power cable and through the relay straight to the correct power supply.
    Just don't forget about the protection diode at the relay coil.
    Regards
    you're welcome ;)
  • #8 16825163
    DawideuU931
    Regards
    you're welcome ;)
    I just want it to be quite easy to do, and I don't have a power supply, and I don't want to spend a lot on making 1m of lighting; d
    So you do not recommend connecting this "Do It Yourself" led strip to a TV that has already run out of warranty?
  • #9 16825166
    Freddy
    Help: 1394
    Rate: 2821
    No, because no one really knows the maximum capacity of the USB socket on the TV.
  • #10 16825288
  • #11 16826121
    endymion
    Help: 6
    Rate: 12
    The standard USB socket has a current efficiency of 500mA and is completely resistant to short circuits and overloads.
    Counting quickly 5V x 0.5A gives us 2.5W which is not enough to power a typical LED strip.
    The best solution will be suggested by a friend @maxipalia .
The discussion revolves around the feasibility and risks of powering a 1m RGB 5050 LED strip using a TV's USB port with a 5v-12v converter. The user, a hobbyist, is concerned about the potential for damaging the TV or its USB port due to the power demands of the LED strip. Responses highlight that while the LED strip may consume around 0.9A, the USB port typically provides only 500mA, which is insufficient. Experts suggest that using a dedicated 12V power supply is safer and more reliable than relying on the TV's USB port, which may not handle the load effectively. The LG 26LK330 model is mentioned, with caution advised regarding the unknown specifications of its USB port.
